Results 11 to 20 of 28
Thread: Digital $30 trans PSI sending unit, works great!
  1. #11
    Ryan, let us know how you go with it.
  2. #12
    Jun 2007
    did a test and here is what the 0-100psi sensor output
    voltage-----Air Compressor Gauge-----1.5" Liquid Gauge
    1.47v-----30psi-----24psi
    1.91v-----40psi-----35psi
    2.36v-----50psi-----46psi
    3.57v-----80psi-----77psi
    4.35v-----100psi-----97psi
    4.48v-----???-------100psi
    Not sure but I'm guessing the 1.5" liquid gauge was more accurate because it is 0-100psi vs the air comp gauge was 0-200. Also note the 1.5" gauge and sensor was at the end of a 50 foot air hose.
    Looks like the formula may be psi = (voltage-.5v)/.04 . What do you guys think?
    9.8@150 . LQ4 Turbonetics Billet 7575@18psi, 6 speed, non-intercooled with meth. Speed Density, open loop, no PE.
  3. #13
    Aug 2011
    yes, the liquid gauge looks more accurate..
  4. #14
    Senior Member Chuck L.'s Avatar
    Feb 2006
    In the FWIW dept:
    I've tested many of the small gauges, [Summit, Jegs type], against the certified gauge on my injector flow bench... Most don't come close.
    However, once the deviation is established, it will repeat at most all the test pressures...
    I've also seen the liquid filled units be affected by under hood heat. [Were rail mounted].
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
  5. #15
    Quote Originally Posted by ryans1000 View Post
    Yes, that's what I get...
    you can simplify it to: psi = (volts*25)-12.5
  6. #16
    Jun 2007
    i'm going to feed the sensor in through the 3 egr pins 41, 47 and 55. When I enable egr in b1301 will that effect any other areas/tables?
  7. #17
    Table B5907 EGR Spark Correction will contribute to final spark.
  8. #18
    Jun 2007
    got it installed, seems to be working fine. so on the stock fuel rail with dual walbro pumps, I'm getting a fast fluctuation from 54.5 to 60psi . Base pressure is set to 58psi. Regulator is before the rails obviously as there is no return port on the rails. This image is with the car off and just the fuel pump turned on. Haven't had time to drive the car yet, maybe tomorrow. Is this normal????
    click here
  9. #19
    Jun 2007
    well my sensor started reading about 10psi too low all the sudden after only a few weeks use. contacted the seller and he sent me a new one. so i'm not sure if this sensor is cheap junk or just a freak defect. I'll keep you guys updated on the new one.
  10. #20
    Thanks for the update.
  1. Digital Dash
    By Harrismarine in forum Gen III V8 Specific
    Last Post: January 5th, 2010, 06:44 PM
  2. Oil Pressure Sending Unit - Recommendations?
    By Johnnydangerously in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2009, 03:37 AM
  3. Replies: 2
    Last Post: April 18th, 2008, 09:00 AM
  4. I6 Scanning Works Great
    By LSRacing in forum Petrol / Gas
    Last Post: February 22nd, 2006, 04:16 PM
