Page 7 of 7 FirstFirst ... 567
Results 61 to 70 of 70
Thread: Problem logging SAE.MAP pid
  1. #61
    Feb 2014
    yes i did thank you, but I think the RTACS is fighting the STFT fixer due to the constant changes , on that note , one of the new blowers is on and i keep getting different changes everyday, which may be the blower breaking in , but i purposely, lowered my whole ve 15 percent to see how the changes were being made and found that when i am making changes especially between 1800-2200 rpm high gear when RATCS is done my converter slips when i let off the pedal raising the rpm to 3000 ???? stock trans values and everything is ok before the changes cant figure that one out
    thanksjoe
    Jim
    Edit , this unit uses a PRV that closes at 1500 rpm and opens when the tps is lowered
  2. #62
    Hmmm, TCC slips when you release throttle...? Post some log files.
  3. #63
    Feb 2014
    i will log some trans stuff tomorrow ,
    thanks joe
    get my pm?
  4. #64
    Jim, thanks for the pm
  5. #65
    Feb 2014
    def needs work on the fueling side , but i was able to get the slip to happen about halfway through the file
  6. #66
    I'll take a closer look later tonite...
  7. #67
    Feb 2014
    long log , but different tune , problem starts out around frame 4k i think now tcc slip is all over the place and it was ok this morning , i was on a fine run with RTACS and the more it changed the worse it gets ,i never had this problem before ,,,attached is a fresh start this morning , im wondering if the prv is screwing things up, its open until 1500 rpm then closes until you let off the pedal as you can see in the log and the ve , not sure how to cure this and im wondering if the trans problems are linked to this , check out the table you will see what i mean
    jim
  8. #68
    Jan 2013
    I know this is an old thread but can I use the calc map on a 04073003 os I added it to the cal pids but it comes up as an unsupported pid
  9. #69
    Quote Originally Posted by codeman_tinck@hotmail.com View Post
    If you are using the V7 software, in the [PIDs F8] tab page, right click on the calculated PID and select "More Info...". That will tell you why EFILive thinks it is unsupported. It is usually because one or more PIDs that the calc PID uses is not selected yet. So make sure all the PIDs that are used in the calculated PID's expression are also selected and supported.
  10. #70
    Jan 2013
    you are correct thank you I've been opening and closing scan alot I forgot to select gm map it works as should much appreciated
    its odd I didnt have this problem with my 0411 but this will work fine
  1. What is the deference between {GM.MANVAC} and {SAE.MAP}?
    Last Post: April 24th, 2008, 06:37 AM
  2. GM.MANVAC vs. SAE.MAP
    By Lennart in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2007, 04:32 AM
  3. Main VE doesn't match MAP.SAE
    By LSs1Power in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2007, 03:11 PM
  4. Why doesn't SAE.MAP not work? (2-bar)
    By Alvin in forum Custom Operating Systems
    Last Post: October 27th, 2006, 06:07 PM
  5. Replies: 5
    Last Post: April 27th, 2005, 01:26 AM
