Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Public Release Update July 03, 2011
  1. #21
    Quote Originally Posted by izaks View Post
    Writing a cal to the controller (today it was a LS1B)
    Everytime I logged a dyno run, and then wanted to write to the controller, had to close and then reload TUNE. Scan Tool loaded the whole time.
    Replying OK to the error message did not work like it used to, now it clears the message and sits idle. If you click Start again (to write to the controller) error msg pops up again.
    Have to close and reload only Tune
    What Windows OS are you running on?
    I know this is probably obvious but I have to ask, did you disconnect the Scan Tool prior to trying to write the cal in the Tune Tool?
    After you get the "can't connect" message in Tune, what happens if you try to reconnect the Scan Tool?
    Does Scan connect ok or does it give the same error?
    P.S. I followed the sequence you posted and it works fine here on Win7 64 bit. I'm using the old USB drivers V2.02.04.
  2. #22
    Lifetime Member izaks's Avatar
    Aug 2003
    Windows XP SP3 (upgraded from WIN 7 a couple of months ago)
    Yes, forget to do that quite often, but no, Scan was disconnected.
    After one of the failures, tried to reconnect to Scan, and it worked fine.
    I can try and recreate using a bench harness (LS1B and E38), but only tomorrow (23:35 is past my bedtime)
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
  3. #23
    Mar 2007
    W/ the latest update, I'm not seeing any GM pids.
    Scan/Tune: 7.5.7 build 170
    BootBlk: 2.7.2
    Firmware: 2.7.14
    OS=12212156
    This was working prior to the update today.
    Here are the details: http://forum.efilive.com/showthread....question/page2 It starts @ post 12.
    The only thing I can think of doing now is trying a reinstall of the SW. Can I dwnld the previous ver from somewhere?
  4. #24
    Quote Originally Posted by FeetDry View Post
    BootBlk: 2.7.2
    Firmware: 2.7.14
    OS=12212156
    See post #12 on previous page.
  5. #25
    Mar 2007
    Yes, I have validated the pids. (Many times, w/ & w/o logging.) Still no GM pids.
    The VPL the I posted doesn't show any GM pids.
    I don't know why.
  6. #26
    Can you edit the desktop shortcut that starts the V7.5 Scan Tool and add /l to the end of the shortcut (that's space, forward slash, lower case L).
    Then start the Scan Tool using that shortcut.
    Having the /l on the end of the shortcut will create a log file called: C:\Program Files\EFILive\V7.5\StartupLog.txt
    Please send that file to me at paul@efilive.com
    Don't forget to remove the /l from the shortcut when you're done or it will just slow you down each time you start the software.
  7. #27
    Paul, next time you generate the E67 cals there's an extra letter (a "b") in the definition for the {B1094} Crank Sensor Type under the Calibration tab (normal startup page with the VIN, OS, etc). Currently it reads "58Xb".
  8. #28
    May 2009
    Default Trouble uploading
    Fixed...didn't realize that I had to download V8 to update the firmware.
Name:	efilive error.JPG
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
  9. #29
    BootBlk: 2.7.2
    Firmware: 2.7.14
    OS=12212156
    In case anyone else is reading this thread, there is additional info here:
    http://forum.efilive.com/showthread....830#post149830
    From post #26 onwards.
  10. #30
    Dec 2006
    I went to flash my truck with the V2. Truck is now dead in the water.
    Dash display shows nothing and starter will not even engage.
    unit erases the computer with yellow light flashing
    Starts programing with the progress bar and yellow light flashing
    about third of the way through flashing, error message comes up: Error $0322 conditions not met or request sequence error
    Tried again and same error.
    Went and loaded my stock tune. Started to do a full flash and receive the following error: $0281 no data
    Any ideas whats going on here.
    Frank
  1. Public Release June 03, 2011
    Last Post: July 9th, 2011, 07:59 AM
  2. Public Release Update June 24, 2011
    Last Post: July 9th, 2011, 06:21 AM
  3. Public Release Update June 06, 2011
    Last Post: June 20th, 2011, 07:12 AM
  4. Official Public Release - Mar 20, 2011
    Last Post: April 2nd, 2011, 10:02 AM
  5. EFILive V7.4.2 Public Update - July 22, 2007
    By eboggs_jkvl in forum Lounge
    Last Post: July 23rd, 2007, 02:07 AM
