After looking around for a while, I decided that there wasn't a nice set of GenIII valvecovers that looked nice, were functional, and didn't cost a mortgage payment. So, using my vendors for my other consumer products, I decided to design my own version. Here are the highlights:The best news? Right now, these look like they will be retailing for $150US per pair. I'm about to commit to the tooling, so if you have any feedback or thoughts, get them in quickly so I can make changes. Otherwise, I'm looking at getting in the first set hopefully by March, in time for racing season.
- Die-cast aluminum valve covers, high quality casting that will come powdercoated a silver grey color.
- 2-1/2" tall to clear the tallest Jesel rockers (like mine) with ease
- Uses the stock gasket for a leak proof seal just like GM
- Includes longer bolts along with a rubber sealed washer
- Hole in top fits a standard baffle grommet and breather available at any speed shop. Additional boss underneath if you want to drill and mount your stock PCV grommet and valve.
- Angled side and underside bosses allow the coil packs to be mounted (optionally) such that the bolts are accessible for valvecover removal with packs in place.
- Position of coil packs allows the use of standard LS1/LS6 spark plug wires
- Positioning lip on bottom side allows easy installation just like stock valve covers
- Optional CNC engraving for additional cost of basically anything you want that can fit on the valve cover
Here is my computer rendering of the models:
http://www.mccordcg.com/pics/mcg_ls1_vc.jpg
http://www.mccordcg.com/pics/mcg_ls1_chevy.jpg
http://www.mccordcg.com/pics/mcg_ls1_chevy2.jpg
http://www.mccordcg.com/pics/mcg_ls1_chevy_red.jpg
http://www.mccordcg.com/pics/mcg_ls1_bb.jpg
After looking at the hideous factory coil mounts, I decided to just do my own style. These are two pieces of aluminum with tapped 1/4-20 holes in them where you can mount the coils to them. Then, you can take this assembly as a single unit and using two 1/4-20 cap screws, mount it to the valvecover. I'll put two small divots in the casting so you would know where to drill. Initial cost on the coil brackets looks to be around $40US.
http://www.mccordcg.com/pics/mcg_ls1_chevy_coils.jpg
http://www.mccordcg.com/pics/mcg_ls1_ta.jpg
I'm committing to tooling for the dies in the next 5 days, so if you have any feedback, let me know so I can look at implementing it.
The graphics would all be extra engraving on our CNC mills. Standard designs (as shown) and custom engravings would all be available at an additional cost. If you can think of some good standard engravings, like Holden, GTO, etc, shoot me a graphic and I'll try to incorporate them to see how they look engraved.
Thanks in advance for your feedback.
