Results 11 to 20 of 29
Thread: How do I boost fool with EFI Live
  1. #11
    Lifetime Member FUBAR's Avatar
    Feb 2011
    That just goes to show how different these trucks are I guess. I had to do it to a friends truck that's running a 66/74/14 to keep him from defueling past 38psi or so actual boost.
    And hey Les, see if I'm making any sense over on the Injector Balance thread will you?
    Thanks,
    06 LBZ, EFILive
  2. #12
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Fubar, i have not dealt with the defueling issue yet... but what voltage (if you still have the log) was he defueling at within that table you rescaled? It seems as though even if you would have left the table stock, the defueling possibly could of been fixed by what it would be calling back to in (F0502).. just seems like that is where it would of been calling to limit the fuel?
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
  3. #13
    Feb 2011
    I rescaled that table and F0522 I believe as well. I look at the log and get back with you later.
    06 LBZ, EFILive
  4. #14
    Lifetime Member 06redram's Avatar
    Jan 2011
    Quote Originally Posted by FUBAR View Post
    FUBAR go to tab Diagnostics parameters D0785 bump 140 to 180 that should stop the truck from defueling
  5. #15
    Feb 2011
    Thanks 06redram. I was just referring to what tables I modified (or maxed out if you will) to take the defueling away. Don't know offhand if I modified that one or not be it that I don't have my laptop in front of me nor are a EFI wizard either. Lol.
    I've always wondered, can "limiting" tables have negative effect on drivability say... if I do in fact want some type of a limiter under a given condition to keep the truck from going out of control?
    06 LBZ, EFILive
  6. #16
    Jan 2011
    It works great on my truck no problems fuels hard and holding at 110mph no drop in rail psi. Stock cp3 and stock injectors just T&C mod fuel rail and mod PRV. Just go for it !!!
  7. #17
    Nov 2009
    Quote Originally Posted by 06redram View Post
    ^^^^This will have no effects on "defueling"..this is simply a fuel pressure limiter Thurmon.
    Fubar, there are select tables that are worth just maxxing out, however, i do like using the limiters for smoke control and driveablilty aspects such as jumpy throttle, part throttle smoke, trucks feel ect. They very much come in handy for making big fuel sane.
    -Kory
  8. #18
    Feb 2011
    Duly noted Dmaxink. If you don't mind me asking, what type of tables do you speak of are worth keeping in check?
    06 LBZ, EFILive
  9. #19
    Jan 2011
    Quote Originally Posted by Dmaxink View Post
    That's great now so that where my smoke coming from. Thanks Dmaxink, still learning
  10. #20
    Nov 2009
    no the smoke in your tune is coming from you asking for full fueling before you even have 1 pound of boost built. Understand the changes you are making fully before you make them, trust me it will save you time in the long run... yes your tune is ramping up the fuel, but it is already at 180mm3 at 6.8kpa (which is under 1psi of boost). Understand, you can ramp up the fuel all you want to mm3-wise, but after 145mm3, the truck is considered to be WOT. This is one of the main tables responisble for your heavy smoke thurmon.
    -Kory Willis
    -Kory
  1. Anyway to fool 411 PCM into thinking its connected to 4L60E for TCC operation?
    By slow89irocz in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 26th, 2010, 08:03 AM
  2. Anyone using EFI Live to control a boost solenoid???
    By spoolinsteve in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 20th, 2010, 04:56 AM
  3. Thanks EFI Live
    By JOHNBOY in forum General (Diesel)
    Last Post: April 1st, 2010, 09:16 AM
  4. Efi live class at efi university
    By Robbie The Wrench in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2008, 02:25 PM
