Results 1 to 4 of 4
Thread: Convert Pass Thru Scan PID list to BBL PID list
    Default Convert Pass Thru Scan PID list to BBL PID list
    Does an easy way exist to convert an existing PID list used for pass-thru logging with the V2 cable to a BBL PID list for the V2 or the AutoCAL?
    BTW - has anyone else noticed that some of the names/descriptions are not the same between the two systems?
    Jason Haines, Project Director
    Lingenfelter Performance Engineering
    http://www.lingenfelter.com
    jhaines@lingenfelter.com
    260-724-2552
    Feb 2006
    It would definitely help if the names were the same across the board. I have usually made my selection, did a quick BBL and upload to confirm what I am getting. I would like to be able to copy a list of PIDS and paste them into another ECM/TCM selection. This would allow me to easily create different combinations like E67/T43 and E67/T42 choices without hand copying each one.
    Al
    Nov 2006
    It would be a nice to download a .pid file straight to the V2 in place of the options.txt
    LC-1 WBO2
    Quote Originally Posted by jrh View Post
    No, but there will be soon. As Al suggested it will be a copy and paste feature that does the PID name conversions automatically.
    Some PID names changed because of the 11 character name limit for BBL.
    Some PID names changes because they clashed with newer PIDs being defined.
    Some PID names changed because they were misleading or confusing.
    You can see the list of name changes in sae_generic.txt under the section *BBLV7
    I've copied them here for easy reference.
    Note: All _DMA PID names in V7 are named _M in V8
    Code:
    # Conversion of BBL PID names back to V7Parameter names
    *BBLV7
    #BBL Name      V7 name
    ; SAE paramaters
    WO2AS11        WO2S11_B
    WO2AS12        WO2S12_B
    WO2AS13        WO2S13_B
    WO2AS14        WO2S14_B
    WO2AS21        WO2S21_B
    WO2AS22        WO2S22_B
    WO2AS23        WO2S23_B
    WO2AS24        WO2S24_B
    EQ_RAT         LAMBDA
    ; GM Enhanced parameters
    ESTDIAG        STATE14
    ETCTAC1        STATE15
    ETCTAC2        STATE16
    ETST           ETCS
    MAF_GM         MAF
    MAPS           MAP
    ACHPRS         ACP
    GENFDC         ALT-F
    TP_A           TP
    FRPS           FPS
    BBVPS          BBS
    DESTQ          DESTRQ
    EOP            EOPS
    EGRCMD         EGRCOM
    TRACTRQ        ACTTRQ
    TTQRET         SEMRET
    BARO_B         BARO
    EOLIFE         EOL
    RUNTIME        RUN_TIME
    MAFSD          DYNAIR_LS2
    EGRCLOSE       EGRPINTLE
    IDLERPM        IDLRPM
    STFTAVG1       SHRTFTAVG1
    LTFTAVG1       LONGFTAVG1
    STFTAVG2       SHRTFTAVG2
    MFFAIL1        MFFAIL
    MFPASS1        MFPASS
    LTFTAVG2       LONGFTAVG2
    FTV            FTP
    CASE           CASEERR
    CURRCYL        CKREFCYL
    FANDC          FANPWMDC
    GENLDC         GENL_DC
    IGN1CC         IGNCOIL1
    IGN2CC         IGNCOIL2
    IGN3CC         IGNCOIL3
    IGN4CC         IGNCOIL4
    IGN5CC         IGNCOIL5
    IGN6CC         IGNCOIL6
    IGN7CC         IGNCOIL7
    IGN8CC         IGNCOIL8
    INJ1CC         INJECTOR1
    INJ2CC         INJECTOR2
    INJ3CC         INJECTOR3
    INJ4CC         INJECTOR4
    INJ5CC         INJECTOR5
    INJ6CC         INJECTOR6
    INJ7CC         INJECTOR7
    INJ8CC         INJECTOR8
    O2H11DC        O2HTRDCB1S1
    O2H21DC        O2HTRDCB2S1
    VSFPDC         FPVSPDDC
    EOT            EOILTS
    FANSPD_DES     FANSPD_ACT
    TSTATE33       TSTATE02
    TSTATE34       TSTATE03
    TSTATE35       TSTATE04
    TSTATE36       TSTATE05
    TSTATE37       TSTATE06
    TSTATE39       TSTATE07
    TSTATE40       TSTATE08
    TSTATE41       TSTATE09
    TSTATE42       TSTATE10
    TSTATE45       TSTATE12
    TSTATE03       TSTATE13
    TSTATE04       TSTATE14
    TSTATE05       TSTATE15
    TSTATE06       TSTATE16
    TSTATE07       TSTATE17
    TSTATE16       TSTATE18
    TSTATE02       TSTATE52
    TSTATE08       TSTATE58
    TSTATE09       TSTATE59
    TSTATE10       TSTATE60
    TSTATE11       TSTATE61
    TSTATE14       TSTATE64
    TSTATE15       TSTATE65
    TSTATE17       TSTATE67
    TSTATE19       TSTATE69
    TCMPSLIP       TCSLIP
    FUEL_MAIN_M    FUELQ_MAIN_DMA
    FUEL_THR_M     FUELQ_THR_DMA
    DSP5_VOLT_M    DSP5_VOLTS_DMA
    SCALCORVE_M    SCALEDCORVE_DMA
    SCALUNCVE_M    SCALEDUNVE_DMA
    TRQCALC_M      TORQUECALC_DMA
    TRQRED_M       TORQUERED_DMA
    IAC_SD_M       IAC_STD_DMA
    IAC_SPN_M      IAC_STPN_DMA
    IAC_SDAC_M     IAC_STDAC_DMA
    IAC_SPNAC_M    IAC_STPNAC_DMA
    IAC_LD_M       IAC_LTD_DMA
    IAC_LPN_M      IAC_LTPN_DMA
    IAC_LPNAC_M    IAC_LTDAC_DMA
    IAC_LDAC_M     IAC_LTPNAC_DMA
    IAC_FRIC_M     IAC_FRICTION_DMA
  1. need help with v2 not read pid list
    By restless@westnet.com.au in forum General
    Last Post: July 7th, 2011, 09:10 AM
  2. GM.E35DSP5_DMA not in my list of PID's
    By foxracingfreak in forum Diesel
    Last Post: September 11th, 2010, 04:44 AM
  3. how to get my pid list to v2?
    By 2004gmc in forum Lounge
    Last Post: May 30th, 2009, 10:52 AM
  4. 98 4l60e PID list
    By 996pilot in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 18th, 2007, 03:53 PM
  5. need PID list for fast wideband
    By joe'sls1 in forum Gen IV V8 Specific
    Last Post: September 25th, 2007, 07:37 AM
Tags for this Thread
