Results 1 to 5 of 5
Thread: Out of range
    Jan 2008
    Default Out of range
    I've read a 2010 Camaro os12633056 and when I opened it in FS v7.5
    got a out of range message P/N idle speed, and the table look
    weird, go to Holden crazy and try to open 2010 Camaro os 12633056
    and the table is weird too but it's ok when i look at os 12639270.
    Can somebody take a look at both files to see if it show the same error ?
    I 've the last version of FS v7.5 built 1.70
    Sylvain
Name:	Out of range  idle speed.jpg
    Sylvain, I notified Tech Support, thanks.
    Thanks Sylvai, that is indeed very wrong. It was a newly added table. I'll get that fixed up ASAP.
    Here's the updated .calz file for that OS, if you copy this in to the folder below then that table will show correctly. This fix will go out as a general release in the next update.
    \Program Files\EFILive\V7.5\Calibrations\E38
    Jan 2008
    Thank a lot.
    Sylvain
  1. LTFT - range vs + range lean rich question
    By mvvette97 in forum Gen III V8 Specific
    Last Post: September 14th, 2009, 06:18 AM
  2. A0011 out of range...
    By brokenfly in forum Custom Operating Systems
    Last Post: October 16th, 2007, 08:35 AM
