Results 1 to 3 of 3
Thread: Fuel MAP RPM scale problem even with new build 170
    Jun 2011
    Default Fuel MAP RPM scale problem even with new build 170
    LMM OS 52628594 displays the RPM incorrectly in the DSP 1-4 fuel base maps. See picturesClick image for larger version.
ID:	11345Click image for larger version.
    Yes you are correct, sorry that didn't get sorted out, it's on the to do list now.
    The main table is correct, the DSP tables should not start at 0 RPM as shown.
    Jun 2011
    just glad I can help make this great tuning software even better!
  1. Replies: 16
    Last Post: June 25th, 2010, 09:59 AM
  2. Build 74 update problem
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 04:57 AM
  3. how to build map to log boost?
    By minytrker in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 23rd, 2006, 10:54 PM
  4. Very lean at idle RPM/MAP problem
    By jnorris in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2006, 10:29 AM
  5. Need help with a load vs. rpm vs. KR MAP!
    By Redline Motorsports in forum General
    Last Post: October 25th, 2005, 03:52 PM
