Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
Thread: Heading to the track in the morning
  1. #11
    May 2009
    Les
    are you changing the axis table for the MAP sensor as well
  2. #12
    Nov 2010
    No..just simply changing the psi to go linear from 0-58psi...I'll try to post a pic tomorrow.
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  3. #13
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Les,
    That was more than likely the issue.
    I just looked at that table and I didn't change it. It still had the 51.4 as the limit and I hadn't rescaled it.
    I could have sworn I did, but apparently not.
    I'll get it loaded up this afternoon and see what it does.
    1207 HP / 1612 TQ
  4. #14
    Jun 2011
    This is the EXACT issue we are having as well. I havent tried rescaling the map voltage tho. PUll to 3k, fall on its face, smoke would go away, shift and pull again thru the next gear. When the tc is locked its more apparent.
    We did better than we thought we would tho, 12.6@107 hitting the limiter at 107.
  5. #15
    Nov 2010
    Here is a screenshot of my MAP voltage table...
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
  6. #16
    Lifetime Member FUBAR's Avatar
    Feb 2011
    Les, I just tried your E3255 map (MAP Sensor rescale), and with the truck idling, I got a P0236 Map Sensor Too High Too Long. Any ideas?
    06 LBZ, EFILive
  7. #17
    Nov 2010
    I have heard of this with stock trucks...possible causes are...dirty MAP sensor..or failing/lazy sensor.
    I have this MAP on 4 trucks right now..and have been doing well with no codes.
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
  8. #18
    Dec 2009
    Quote Originally Posted by FUBAR View Post
    You need to adjust the turbo parameters so it doesn't look for the boost error....
    1207 HP / 1612 TQ
  9. #19
    Feb 2011
    Yea, already touched on those Rich. Les, I don't doubt you at all, just curious. I'll play around with it when I have more time. Speaking of what you said though...do many people clean their MAP sensors?
    06 LBZ, EFILive
  10. #20
    Nov 2010
    I clean mine as often as I clean my air filter....but I am very particular about my set-up.
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
  1. My car is lean in the morning
    By wesam in forum Gen III V8 Specific
    Last Post: June 19th, 2010, 09:26 PM
  2. Finally on track.
    By willn in forum Gen III V8 Specific
    Last Post: August 3rd, 2009, 12:44 PM
  3. Can not get a 4-5 shift out of A6 at Track
    By E.A. in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: November 24th, 2008, 08:04 AM
  4. bidirectional control wrong heading
    By madprof01 in forum General
    Last Post: February 16th, 2006, 08:45 AM
