Results 1 to 7 of 7
Thread: efilive wont open saved e38 files after update to build 170
    Jan 2007
    Default efilive wont open saved e38 files after update to build 170
    last night i updated to the new public release build 170, now i cant open any saved e38 files, tried several i already have on my computer plus a bunch from holden crazy
    just get the badfileformat message
    anyone else got this problem.
    Jan 2007
    problem fixed,, had to do full uninstal and reset all registry keys during fresh instal
    Senior Member alian's Avatar
    Jun 2008
    Quote Originally Posted by mrrattle View Post
    Had the same problem, also lost a heap of pids out of loggs that were already saved prior to update. I reinstalled the program and was fixed.
    Ian
    Jul 2007
    It looks like it's something in the "online update" process. I also had this, after doing an auto update. After manually downloading and installing over the top, all was fine. I did not need to un-install the previous version.
    Simon
    I think Paul disabled the auto update as it wasn't updating correctly, as you guys found, downloading the install exe's off the website fixes the problem.
    Apr 2009
    I actually had the same problem with a manual update. The fix ended up being a re-run of the update install but selecting the "return to factory defaults" for install locations before committing. There must be a definition file misplaced or something otherwise.
    ~Greg
    Calibrated Success - EFI Training and Tuning Done Right
    GM Beginner's Guide DVD available now through Summit!
    Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    I had the same problem.
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
  1. Fuel MAP RPM scale problem even with new build 170
    By Black6spdZ in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 7th, 2011, 12:18 PM
  2. Truck wont idle during open loop speed density
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 23rd, 2006, 06:43 AM
