Can you post a screenshot.
Dvt w/ IAC counts set to 80 - Data tab shows 80
Click rpm....data still shows IAC@ 80 steps
What happens if you uncheckmark the idle control and then recheckmark it...?
Same thing Joe.......
I sent this to Tech Support to see if they can find a problem.
Thanks Joe.
Joe,
It idles fine.
I sooo want to kick my own ass right now.
I bought the whipple used. It was already put together and even had the old throttle body and bracket on it for cruise and gas pedal. During the first few days that it wouldn't idle, I thought maybe it was from a different year and set up different so I swapped out for my stock one.
Never checked the gasket. Since its on a stud i left it on and just swapped the throttle bodies.
sure enough, I take it off, and the TOP side is not up.
On a side note, the BIDI controls work fine now
Thanks for the help, patience, and I'm sure I'll have more questions, I just hope they're not as stupid as this.
-Jerry
Hi Jerry,
BiDi works as expected thanks for posting back.
No worries (stuff happens)... glad you got it going
