Hi Guys, need some advise / help runing a 383ci ls1 with gt42 on 14psi and e85 with 80pound injectors , the duty cylce is thu the roof they sill seem to be delivering the required amount of fuel 0.78lamba but they r hitting 140% at full noise on 90psi fuel pressure so i need something bigger the biggest high impedance injector i have found so far r 1000cc but i don't reckon they will do the job is there a way of getting a low impedance injector to run on a ls1 pcm unless some one knows were to getting a 1600cc high impedance injector?- thanks
