Results 1 to 4 of 4
Thread: E38 Reduced power mode
    Mar 2008
    Default E38 Reduced power mode
    I was having some issues tuning a 2010 Camaro. After pulling my hair out and still not finding the issue, I've decided to try a new E38 PCM. For now let's not discuss what those issues were. I got another PCM from a 2010 Camaro with the same service #. After installing the new PCM, I did a full reflash with all the resets and relearns (anti theft, crank, idle, imobilizer so on). I even had onstar do a relearn procedure. I transferred the VE tables and MAF tables from the previous PCM. The car drives perfectly with all the right trims but under medium to hard acceleration it goes into Power Redution Mode (No codes). What's causing this? What can I do to prevent this?
    What is done to the car????
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Mar 2008
    Headers, air box, Magnuson SC. I've done 15-20 of these and never had a problem tuning them. After having problems with the fuel trims, I diagnosed and narrowed the problem to the PCM. With the new PCM everthing is as it is supposed be except going into power reduction mode. The old PCM did not do this.
    Apr 2008
    easy, post your file and will do it for you. Then, you just need to compare both files to view the changes.
    Regards,
    Odd Boy
  1. Reduced power mode Again!...........
    By FreddyG in forum Gen III V8 Specific
    Last Post: November 16th, 2007, 07:08 PM
  2. Reduced Power Mode...............
    Last Post: November 13th, 2007, 05:13 PM
  3. reduced power mode
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2007, 02:12 PM
  4. Reduced Power Mode but No DTC
    By CTP Racing in forum General (Petrol, Gas, Ethanol)
    Last Post: July 20th, 2006, 07:50 AM
