Results 1 to 5 of 5
Thread: o6 Cobalt
    Nov 2006
    Default o6 Cobalt
    Does EFILive support the 2006 Chevy Cobalt with the 2.2L L61 I-4?
    If it does, what is the controller name/number I need to use. I have spent a lot of time looking over this forum and main site looking for the answer and am more confused.
    Thanks,
    jc
    SIERRA 2500HD
    LLY - ZF6 - 4WD
    445hp/889tq
    Lifetime Member Gregs's Avatar
    Sep 2008
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Aug 2010
    Hello JC,
    Looks like 2006 - 2007 Cobalt's with the 2.4 L engine are supported - these use the E67 ECM. Also looks like 2007 - 2010 Cobalt's with the 2.2 L engine are supported - these use the E37 ECM.
    It appears your 2006 Cobalt with the 2.2 L engine is not supported. I don't do 4 cylinder tuning - the above is merely from a review of published supported vehicles.
    Regards,
    Taz
    Nov 2006
    I kept coming up with what Gregs listed. I am just making sure I wasn't missing it. All's I wanted to do is some logging on it. Oh well, Thanks for the replies.
    jc
    SIERRA 2500HD
    LLY - ZF6 - 4WD
    445hp/889tq
    If you want to just log it, there is a VERY good chance you can. Try connecting using the E38, E37, and/or E67 to see if you get data. Obviously the DMA PIDs wont be defined as they are OS specific, but the generic VSS, MAP, IAT, RPM... will work.
  1. 06 chevy Cobalt
    By Dave T in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2011, 10:56 PM
  2. Looking for Cobalt SS cal file?
    By N0DIH in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 9th, 2011, 03:54 AM
  3. 2.4L Cobalt Tuning Help
    By Meister in forum E37, E38 & E67 PFI ECM's
    Last Post: October 11th, 2010, 01:22 AM
  4. 2.2L cobalt 2008
    By duramaxdaddy29 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: February 21st, 2009, 04:02 AM
  5. Support for 06 Cobalt ss/sc 2.0L
    By stkshkr in forum E37, E38 & E67 PFI ECM's
    Last Post: June 12th, 2008, 03:38 PM
