Results 1 to 4 of 4
Thread: Tuning the AFM on a 2010 LMG
    Senior Member Naf's Avatar
    Aug 2006
    Question Tuning the AFM on a 2010 LMG
    OK, i am going to be getting the CCA 189-423-13 cam and phaser kit for my truck.
    I am curious what should my settings be for the cam phasing section be?
    Or just leave them blank?
    American Muscle, European Design, Japanese Tactics
    Aug 2006
    bringin this back to life. But now i have a L98 with flex fuel, Ported LS3 heads and AFM.
    how do i know if i am doin good on the timin for the AFM?
    Aug 2006
    Quote Originally Posted by Naf View Post
    Latest news.
    I looked at the escalade tune and noticed a slight increase in AFM timing vs the main table. So i mimiced it on mine. I have noticed a stronger pull in afm mode with even a higher speed in afm. But i am still curious to know if anyone else pioneered this. I have noticed a sound when in afm but now it sounds stock. There is a slight increase in rpm but nuttin drastic. I will be installin a 4" maf and see it it helps with the AFM mode.
    see tune for reference
    Aug 2006
    Still messin with the timing
    At one point i had 9 degrees of knock just in AFM mode. I dropped the timing by 1 degree and i am seeing only 6 degrees at 1400-1600rpm.
    I need to keep the timing up for the truck doesnt have enough power to keep it in 4cyl mode at 100kph and 1500rpm. If i keep the timing up i get knock, but it holds. Lower the timing i get less knock but it doesnt stay in 4cyl mode.
    This is a problem...
  1. 2010 5.3 AFM tuning
    By CDN SS in forum Petrol / Gas
    Last Post: April 7th, 2011, 07:31 AM
  2. Tuning a 2010 Camaro
    By pavetim in forum Gen IV V8 Specific
    Last Post: January 12th, 2011, 02:05 PM
  3. 2010 Camaro Disabling AFM
    By Tommy in forum Gen IV V8 Specific
    Last Post: September 14th, 2009, 09:10 AM
  4. 2010 Camaro tuning
    By GMPX in forum Gen IV V8 Specific
    Last Post: August 1st, 2009, 01:32 PM
  5. First GenIV LMG swap AFM data logs
    By harascho in forum Gen IV V8 Specific
    Last Post: May 7th, 2009, 08:25 AM
