Results 1 to 2 of 2
Thread: EQ or AFR
    Question EQ or AFR
    First allow me to say hello to all. I have a problem with doing the SD auto Ve set up as it states to set it by either EQ or AFR. Mine only states Lambda at the 0.833. So which of the values am I to use with this? Any help would be great as I am new to this kind of tuning.
    Jan 2005
    First off you didn't give enough information to describe your problem.
    To change calibrations from Imperial/metric:
    Click on Edit> Configure calibrations, high light the calibration you want to change and make the change at the bottom of the page.
    To change Lambda, AFRs, EQ ratios:
    Click on Edit> Properties and make your change from the drop down window of the value that you want to change.
    Hope this helps. Curt
    99C5, mn6, Vortec T trim, Snow meth injection, AFR 205s, ARP studs,Comp 224*112*+2*.580", YellaTerra RRs, PRC Ti's w/dbls, Supermaxx LTs, No Cats, Corsa Indys, LS6Intk, Hurst, Fikse Aro18"s. Pilot Sports 315/30,265/35, 04ZO6 Shocks Hotchkis bars, EBC YellowStuff pads, SS hoses, LM-1, EFILive, 2002 OS. RPS dual disc Clutch, DTE Strut Brace & output shaft.
