Thread: Help! Sputtering/Cutting Out
    Jul 2011
    Exclamation Help! Sputtering/Cutting Out
    Okay, so I went through everything I know to try and get rid of this problem but I can't figure it out.
    On my 3,4, and 5 tunes my truck cuts out (85hp-120hp)
    Some people said it could be a boost limiting table? What table are they talking about???
    Thanks in advance guys.
    -Jerry
    Jul 2011
    Oh yeah... truck is stock trans/stock turbo with exhaust, intake, and IAH deleted... Also have a ADII 150
    Nov 2009
    have you tried to contact your tuner? If so, they should verify that everything is how it is supposed to be for your setup. if tune 1&2 are fine then it is more than likely for sure in the tuning assuming you have adequate fuel press with the AD.
    -Kory
    http://www.PPEI.com/
    Jul 2011
    I am doing this myself. Previous owner had a J/A on the truck, and I have EFI from my T/A from Black Bear.
    Fuel Pressure isnt the issue.
    Nov 2009
    Considering it is your tune, i would be happy to take a look and tell you what may be limiting you. Otherwise, i suggest logging and seeing what is not acting as commanded.
    -Kory
    Jul 2011
    PM me your email, and I'll send it to you.
  1. cutting off injectors
    By quick6.6 in forum Diesel
    Last Post: April 7th, 2011, 11:17 AM
  2. DFCO cutting out too soon
    By Wolfie in forum Gen III V8 Specific
    Last Post: February 12th, 2008, 02:51 PM
  3. spark cutting out
    Last Post: September 16th, 2007, 11:34 PM
  4. Cutting and Pasting
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 29th, 2006, 06:43 PM
  5. 98 vette cutting fuel at wot
    By red12secz28 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 28th, 2005, 02:29 PM
