It goes through all the steps until this
All help would greatly be appreciated
Did you update to the newest software and firmware if not do so. That should fix it. How to update go to start, all programs look for EFILive high light V7 drop to tools check for updates than high light firmware programmer do the same for V8 update
Yes and double checked that
If that does not work uninstall V7 and V8 then reboot and reinstall V7 and V8
Tried that to..............
Could you please attempt to read the ECM using the V8 software? if it fails please see this knowledgebase article and send me (support@efilive.com) the file relating to the failed attempt.
Andrew
EFILive Crew
I am also having a issue with an lb7 that is like this.. everything is up to date and i tryed pulling fuses and unhooking batterys... this is what i get..
19:55:20.217: Scanning for EFILive FlashScan V2 HAPI
19:55:20.233: Autodetect interface ...
19:55:20.389: Interface firmware version: 2.7.14
19:55:20.389: Connection to [FSV2] interface is OK
19:55:20.404: USB driver version: 2.8.20
19:55:20.404: USB library version: 3.2.4
19:55:20.404: Interface firmware model: FSV2
19:55:20.420: Interface firmware model: FSV2
19:55:20.420: Interface firmware version: 2.7.14
19:55:20.950: Autodetect interface ...
19:55:20.966: Interface firmware version: 2.7.14
19:55:20.966: Connection to [FSV2] interface is OK
19:55:20.966: Autodetect PCM...
19:55:21.996: PCM not detected.
19:55:21.996: Interface firmware date: Jul 03, 2011
19:55:22.011: FlashScan serial number: 003750325084
19:55:22.011: FlashScan license number: 003750325084
19:55:22.027: Disconnecting ...
19:55:22.214: CAN-VPW Bridge Deactivated
19:55:22.214: Disconnected
19:55:22.869: Scanning for EFILive FlashScan V2 HAPI
19:55:22.885: Autodetect interface ...
19:55:23.088: Interface firmware version: 2.7.14
19:55:23.103: Connection to [FSV2] interface is OK
19:55:23.103: CAN-VPW Bridge Activated
19:55:23.166: Current protocol set to: "SAE J1850 VPW"
19:55:23.166: Autodetect PCM...
19:55:23.212: Connection to PCM is OK
19:55:23.212: Current protocol: "SAE J1850 VPW"
19:55:23.415: USB driver version: 2.8.20
19:55:23.431: USB library version: 3.2.4
19:55:23.431: Interface firmware model: FSV2
19:55:23.446: Interface firmware model: FSV2
19:55:23.446: Interface firmware version: 2.7.14
19:55:23.462: Interface firmware date: Jul 03, 2011
19:55:23.462: FlashScan serial number: 003750325084
19:55:23.478: FlashScan license number: 003750325084
19:55:23.743: Getting status...
19:55:23.774: Status: OK.
19:55:24.492: Bootloader version: DLB7_v1.3R (0496-61DA)
19:55:24.492: Preparing ECM for reading flash...
19:55:24.523: ECM seed is: $00FF
19:55:24.523: Unlock attempt 1 of 4
19:55:24.882: Unlock attempt 2 of 4
19:55:25.240: Not ready, waiting 1 second for retry...
19:55:26.488: Not ready, waiting 1 second for retry...
19:55:27.736: Not ready, waiting 1 second for retry...
19:55:29.000: Not ready, waiting 1 second for retry...
19:55:30.248: Not ready, waiting 1 second for retry...
19:55:31.496: Not ready, waiting 1 second for retry...
19:55:32.744: Not ready, waiting 1 second for retry...
19:55:34.008: Not ready, waiting 1 second for retry...
19:55:35.287: Not ready, waiting 1 second for retry...
19:55:36.535: Unlock attempt 3 of 4
19:55:36.894: Unlock attempt 4 of 4
19:55:37.268: Not ready, waiting 1 second for retry...
19:55:38.516: Not ready, waiting 1 second for retry...
19:55:39.764: Not ready, waiting 1 second for retry...
19:55:41.028: Not ready, waiting 1 second for retry...
19:55:42.276: Not ready, waiting 1 second for retry...
19:55:43.524: Not ready, waiting 1 second for retry...
19:55:44.772: Not ready, waiting 1 second for retry...
19:55:46.020: Not ready, waiting 1 second for retry...
19:55:47.283: Not ready, waiting 1 second for retry...
19:55:48.531: Initializing ECM...
19:55:49.389: Initializing ECM, step 1 of 4
19:55:49.389: Initializing ECM, step 2 of 4
19:55:50.169: Initializing ECM, step 3 of 4
19:55:51.682: Initializing ECM, step 4 of 4
19:55:51.963: ECM lock has been re-armed, attempting to unlock ECM again...
19:55:51.979: ECM seed is: $00FF
19:55:51.979: Unlock attempt 1 of 4
19:55:52.338: Unlock attempt 2 of 4
19:55:52.665: Not ready, waiting 1 second for retry...
19:55:53.898: Not ready, waiting 1 second for retry...
19:55:55.146: Not ready, waiting 1 second for retry...
19:55:56.409: Not ready, waiting 1 second for retry...
19:55:57.657: Not ready, waiting 1 second for retry...
19:55:58.890: Not ready, waiting 1 second for retry...
19:56:00.122: Not ready, waiting 1 second for retry...
19:56:01.354: Not ready, waiting 1 second for retry...
19:56:02.618: Not ready, waiting 1 second for retry...
19:56:03.866: Unlock attempt 3 of 4
19:56:04.225: Unlock attempt 4 of 4
19:56:04.584: Not ready, waiting 1 second for retry...
19:56:05.816: Not ready, waiting 1 second for retry...
19:56:07.048: Not ready, waiting 1 second for retry...
19:56:08.312: Not ready, waiting 1 second for retry...
19:56:09.560: Not ready, waiting 1 second for retry...
19:56:10.808: Not ready, waiting 1 second for retry...
19:56:12.040: Not ready, waiting 1 second for retry...
19:56:13.273: Not ready, waiting 1 second for retry...
19:56:14.536: Not ready, waiting 1 second for retry...
19:56:15.784: Initializing ECM...
19:56:16.533: Initializing ECM, step 1 of 4
19:56:16.533: Initializing ECM, step 2 of 4
19:56:17.282: Initializing ECM, step 3 of 4
19:56:18.764: Initializing ECM, step 4 of 4
19:56:19.029: ECM lock has been re-armed, attempting to unlock ECM again...
19:56:19.185: Initializing bootloader...
19:56:19.248: Error: Failed. Controller has returned to normal operation, please retry the operation.
19:56:19.466: Initializing bootloader, step 1 of 3
19:56:19.466: Error
19:56:19.466: Disconnecting ...
19:56:20.371: CAN-VPW Bridge Deactivated
19:56:20.371: Disconnected
19:56:26.752: Done!
I have the same symptoms. Have you had any success yet?
Try with the latest software/firmware: Release-Candidate-2-Aug-19-2011
Current versions: V7.5.7.178, V8.2.1.168, bb 2.07.03, fw 2.07.21.
Edit: latest software is now V7.5.7.180, 8.2.1.170, 2.07.03, 2.07.22.
Please download the pre-release version which has been pretty comprehensively tested. It is available from our forum thread HERE.
You need to download both the V7 and V8 versions and update your FlashScan V2 bootblock/firmware with the versions included in the V8 install.
Here are a couple of knowledgebase articles relating to software and firmware updates for future reference:
- Software updates (get from forum thread this time though).
- Firmware updates
If you still have issues please see THIS knowledgebase article and email me (support@efilive.com) with the trace information (just the file for the failed flash). Please try both V7 and V8 flashes.
Andrew
EFILive Crew
