Results 1 to 7 of 7
Thread: First time tuning
    Jan 2006
    Question First time tuning
    I just started using EFI and I have found myself at a bit of a loss. As I was using the AutoVE tutorial, it states to set the PE modifiers based on RPM using either the EQ or AFR. Unfortunately, Mine states Lambda. I could be stupid and am just missing the whole thing as to which one i should use. I do have the LC1 hooked up. So my question is which set of values do I use?
    Oct 2005
    Goto edit/properties/display tab and change the units to whichever you prefer. I like AFR myself.
    2014 VF SV LS3 Maloo.
    Jan 2006
    Thank you for your assistance.
    Jan 2006
    Now should it automatically set the map to the set values in the tutorial or is that going to be a manual setting process?
    2004 Z06 LG pro long tubes w/3" highflow cats, 3" X-Pipe, WCC Hurricane Ram Air, GMPP 60.7cc CC heads, P&P 250cc intake, 85cc Exhaust, CompCams .571/.573 228/230 LSA110. MagnaCharger 5psi boost. 521 RWHP 493 RWTQ
    Oct 2005
    Smile
    The EQ ratio is the same as lambda. The value is derived from taking the commanded AFR divided by the stoichiometric correct AFR of 14.63. Therefore, an EQ of 1 = 14.63:1 AFR. EQ/Lambda values < 1 indicate a richer AFR while values > 1 indicate a leaner AFR.
    You can do as suggested and change the setting to display AFR which is usually easier for people to relate to than EQ or Lambda. Whatever turns your crank.
    EQ Ratio and Lambda are only the same when AFR is stoichiometric.
    EQ Ratio and Lambda are the inverse of each other.
    • EQ Ratio = stoich/AFR
    • Lambda = AFR/stoich
    EQ RAtio is <1 when AFR is lean, and >1 when AFR is rich.
    Lambda is <1 when AFR is rich, and >1 when AFR is lean.
    See image.
    Oct 2005
    ... partly why I like AFR.. doesnt matter if you forget which way round they are.
    And yes, you have to check/set the fueling manually
  1. Real Time tuning w/o Road Runner?
    By Treed ya in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2008, 06:40 PM
  2. HP Tuners Custom OS for Real Time Tuning compared to EFILive RTT?
    By N0DIH in forum Custom Operating Systems
    Last Post: July 14th, 2007, 03:23 PM
  3. Spark tuning in real time....
    By Redline Motorsports in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 18th, 2007, 10:15 AM
  4. RoadRunner Real Time Tuning
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 08:47 AM
  5. Live Real Time Tuning?
    By Nox in forum General (Petrol, Gas, Ethanol)
    Last Post: June 27th, 2005, 02:08 PM
