Anyone have a theory as to what is going on in this log?
I can feel an intermittent "bump"/miss while cruising around 100 KMH. I can also feel significant timing being pulled in a periodic manner.
Taking a look at the log it was obvious that 17 to 18 degrees of timing was being pulled intermittently for no apparent reason. On my tiny notebook I almost missed the similalry periodic dips in INJC2 that probably correspond to the bumps that I was feeling. I am running a OLSD tune. What could cause the bank 1 and bank 2 duty cycles to diverge when there is no trimming? There are also instances at higher throttle positions where it is INJDC1 that dips. Obviously I can't get into the throttle much.
Not sure why it would make any difference but this was more noticeble today after I drained the 114 race gas and refilled with 94 E10. I'm running ID 1000 high Z injectors that come with full data for the EFILive tables. Also running a Roadrunner PCM. It was in RTACS mode today when this issue was really noticeable. I see similar but fewer timing dips in a non RTACS log from yesterday with race gas still in the tank, but I don't see much variance betwwen banks 1 and 2 duty cycles.
