Results 1 to 10 of 10
Thread: map pressure decreases under full throttle as rpm increases
    Oct 2008
    Default map pressure decreases under full throttle as rpm increases
    hi i did a few logs last night after a while of no tuning and taking my tune back to stock, and noticed that under full throttle the map readings would start decrease as rpm increases,
    ie at 1782rpm and 100% throttle there was 102kpa but at 5480 rpm it had dropped off to 96kpa.
Name:	map drop off.JPG
    My question is, is this normal or does this indicate that i have restrictive intake/air filter?
    VT II SS 5.7l ls1 with ls6 intake, 28lb injectors, otr
    Jul 2008
    Welcome to the Forum:
    Unless you are going full throttle up a hill or mountain it is not normal. Perhaps a manifold intake leak, bad MAF, bad catalytic converter..Too many things to guess at.
    Check out this sticky for a start: http://forum.efilive.com/showthread....nt-Good-Tuning
    Lifetime Member Mr. P.'s Avatar
    May 2007
    You definitely have a restriction somewhere; try making a run without the air cleaner element (maybe it's dirty?) I've also seen plastic CAI boxes & tubing collapse in on itself during WOT. And as Shawn suggested a clogged cat will cause this too.
    Mr. P.
    2003 Silverado SS, with Novi-1500 "CAI mod"
    EFILive V 7.5 COS-3 (OLSD, for now!)
    Oct 2008
    thanks, i'll take it for a run tonight with and without the air filter and see what happens.
    Mar 2005
    hi, this is completely NORMAL for a stock intake system and you should not be concerned!!! I've seen 100's like this
    Fitting a good high flow (less restrictive) intake usually ends up with 97 to 98 KPA at the rev limit netting 8 to 10kw at the wheels gain....sometimes more once you redo the timing as the load points change under full load with a different intake.
    My 2c.
    Mike
    "Just a tune > yeah right !!!! "
    Sep 2008
    I'm with the alchemist on this one!
    cheers
    Oct 2008
    Quote Originally Posted by The Alchemist View Post
    My 2c.
    Mike
    sorry to bring up an old thread, the intake was the cause, i fitted an otr and now at wot the vac starts at 102 and only goes to 100kpa and feels much more lively
    Thanks for posting your results
    Senior Member Naf's Avatar
    Aug 2006
    Check your airfilter...I found mine was restrictive above a certain airflow and it caused my map to drop at WOT on the dyno...
    YOu will notice the MAF will also decrease as the map decreases, these are signs of a restrcitive filter...You will also notice the mixture will lean out no matter how much PE or MAF you add
    American Muscle, European Design, Japanese Tactics
    Senior Member Sid447's Avatar
    Jul 2005
    Always considered it normal,
    For MAP do drop off as speed rises due to an increasing positive air flow being forced into the intake system (ram air effect) which should be more pronounced with a straight OTR type intake.
  1. Spark retarding under full throttle???
    By alian in forum Gen IV V8 Specific
    Last Post: January 1st, 2015, 07:18 PM
  2. MAFless Full pressure
    By L31Sleeper in forum Custom Operating Systems
    Last Post: August 5th, 2010, 11:02 AM
  3. Rail Pressure past 3000 RPM
    By JoshH in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 20th, 2008, 01:38 PM
  4. Full line pressure with A4 SD tune
    By jnorris in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 21st, 2006, 11:20 PM
  5. Replies: 10
    Last Post: July 9th, 2005, 03:25 PM
