Results 1 to 2 of 2
Thread: Need a little help with the calc_pids text file
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default Need a little help with the calc_pids text file
    After downloading the calc_pids text file and putting it into the My documents efi live 7.5 user configeration are you supposed to copy it to the existing Cacl_pids.txt file of just copy it into the user configeration?
    Then after it is copied there one should be able to go into the scan tool and pull it up under the "tune" section. Correct? Sorry been having a lot of trouble with trying to download any text files at all. any help would be greatly appreciated.
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Jul 2008
    I always copy it (save) to the existing calc_pids.txt file (thats called overwriting). If you just Save it to user Configuration..it will not work.
    Whether you pull it from the System Tab I.E. Calculated, Tune, Tuning..depends on the the 'System' is was saved to. In the Example below..the System was "TUNING".
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code PRN SLOT Units System Description
    CALC.CL F032 CLC-00-032 factor Tuning "Closed Loop (based on EQIVRATIO)"
    Hope that helps.
Name:	My Documents.PNG
  1. Help with calc_pids.txt file...willing to paypal money
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: October 5th, 2010, 01:59 PM
  2. Option Text not Found
    By Jason S. in forum FlashScan V2
    Last Post: December 20th, 2008, 08:22 AM
  3. LC-1 calc_pids file and sae_generic files
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: July 25th, 2005, 11:44 PM
