Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 112
Thread: Very lean at idle RPM/MAP problem
  1. #11
    Senior Member WicketMike's Avatar
    Nov 2003
    Quote Originally Posted by Black02SS
    How can B3617 be the cause? If the car is at idle I don't see how a PE table can effect it. I too have the same problem and I notice a trend here... All three of us have 30# SVO's... Coincidence..
    i have stock injectors
  2. #12
    Oct 2003
    Injector offset table????
  3. #13
    Lifetime Member jfpilla's Avatar
    I don't know what the cause is but I'm curious. Not concerned, just curious.
    Doesn't the car use PE for some time after startup? If it doesn't then B4901 gets the change to within 1 point or so short or another table could be involved or my extrapolation could be bad. B4901 seems to be involved since the AFR does richen as g/s increases.
    I don't think the injectors are the issue in SD at startup.
    However, if they don't flow as advertised, it may be one reason for commanded and actual AFR not matching up in WOT PE.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  4. #14
    Try changing your injector timing at cold start temperatures to the same timing value at normal operating temperature.
    I have no reason to believe that will solve anything, other than it causes a difference at different operating temperatures, which is the only clue that is available.
    Just thowing ideas into the ring.
  5. #15
    Quote Originally Posted by bink
    Hey Joel,
    The offset table does not reference temperature in HPT or EFI but I think it does in Edit. The injector timing tables do reference temperature, so they could be involved.
    Someone let me know if B3617 is or isn't involved in open loop when not
    WOT.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  6. #16
    Nov 2003
    that could be it B3702, because at 176f (80c) is when that table reaches its highest setting. which is the tempature i am seeing where it richens back up to where its suppose to be.
    98' White TA A4 TSP 231/237 PP Stage II 59cc heads
    401rwhp (unlocked) 1.594 60'-11.60 e.t.-116.98 mph
    98' Sport Gold Metallic TA M6 - 13.39 e.t. Bone Stock
    My Trans Ams
    2006 Chevy Monte Carlo SS 5.3L LS4 (wifes car) stock (for now)
  7. #17
    Jan 2004
    Quote Originally Posted by WicketMike
    jnorris point this out to me as we were discussing this the past few days and I agree that I "think" it may help the issue. I won't be able to test my theory until Monday.
    Hey Paul/Ross - Is the car in PE at all upon startup?
  8. #18
    Nov 2003
    Here is what I have tried last night and today and the results.
    • Changed the OLAF table idle AFR at low ECT temps. back to the 13.3 values which were 11.2 to offset the lean condition.
    • Put the stock IAC Effective area table.
    • Used the 2002 B3702 and B3703 tables
    Although the commanded AFR at low ECT did not match my WB the AFR was not 17 – 18:1 lean but was in the 15.8:1 range. As the ECT increases the gap between the command AFR and WB AFR narrowed. This was a cold start.
    Today I saw jfpilla’s post about B4901 and B3617. I zeroed out the B3617 table and flashed the PCM. When I started (ETC =21c cool start) the car the AFR was still a little leaner than the commanded AFR. In the 1st min the commanded AFR avg was 12.49 and the WB average was 14.3. Within 2 min of the startup (ECT = 50c) the commanded AFR and the WB AFR were within .3 points of each other.
    I think that with some tuning of the OLAF table in the cool ECT at idle MAP this lean startup problem can be solved.
    So overall I had good success with resolving my lean start problems. Tomorrow morning will be the real test.
    John
  9. #19
    Nov 2003
    My take on B3702 Injection Timing and B3703 Injection Timing Trim tables.
    By the description of these tables it seems that they are values that the PCM uses to open the injectors earlier in the piston cycle based on ECT. The IPW stays the same.
    At 6000 RPM 2.5 – 5.5ms is not significant. These tables will have the most affect on fueling at low RPMs.
    In looking over stock flash files the 99-02 F-body (A4 and M6) cars are the same, only the 98s are different. The few Corvette files I looked are different than the F-body cars.
    On the 98 A4 Vette the Injection Timing Trim table is the same and the Injection Timing table is about .2 higher.
    Are the difference in these values from 98 and 99-02 PCM driven?
    John
  10. #20
    Jan 2004
    I have already zero'd out B3617 on my tune but still see it. I need to check to see if I can't find the post you are refering to.
    Quote Originally Posted by jnorris
    John
  1. Lean AFR Problem
    By nm2769 in forum Custom Operating Systems
    Last Post: April 17th, 2010, 05:41 PM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. COS 04140003 lean problem
    By AGRO in forum Custom Operating Systems
    Last Post: June 23rd, 2007, 11:20 PM
  4. LS2 402 lean idle
    By white2000ta in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2006, 04:59 AM
  5. Lean idle?
    By Texas Terminator in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2006, 10:06 AM
