To confirm that the B3617 table truly had an affect on the cold ECT AFR I loaded PCM files with and without this table being zeroed out. With the table at stock values and zeroed out the AFR on the WB was the same. I have put this table back to stock.
I have for the most part corrected my cold ECT lean problem by putting in richer than desired values at low ECT idle MAP positions in the OLAF (B3605) table and using modified 1998 B3702 and B3703 tables. See below:
B3605 at MAP 50-55/-10c-70c
12.070636
12.070636
12.070636
12.070636
12.070636
12.524798
13.094107
13.895787
14.628573
B3702 and B3703
2.550781
2.550781
2.550781
2.550781
2.550781
2.550781
3.550781
4.554688
4.554688
4.554688
4.554688
4.554688
4.554688
4.554688
4.554688
4.554688
