Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 112
Thread: Very lean at idle RPM/MAP problem
  1. #81
    Oct 2003
    Wicket Mike - so in both cases when you put your stock "backup VE table" in the afr was stoich?? Are you Open loop with the MAF and SD?
  2. #82
    Senior Member WicketMike's Avatar
    Nov 2003
    Quote Originally Posted by bink
    maf plugged in, stock backup VE table, AFR is stoich during warmup
    Maf plugged in, tuned backup VE table, AFR is real lean during warmup
    Maf unplugged, SD mode, stock backup VE table, AFR super rich during warmup
    Maf unplugged, SD mode, tuned backup VE Table, AFR real lean during warmup
    ill test it again tommorow
    98' White TA A4 TSP 231/237 PP Stage II 59cc heads
    401rwhp (unlocked) 1.594 60'-11.60 e.t.-116.98 mph
    98' Sport Gold Metallic TA M6 - 13.39 e.t. Bone Stock
    My Trans Ams
    2006 Chevy Monte Carlo SS 5.3L LS4 (wifes car) stock (for now)
  3. #83
    Jan 2004
    Quote Originally Posted by WicketMike
    I maybe have missed this, but when you did these tests, what was the commanded afr for each test and the actual? Also like bink asked, were you in open loop or closed? I would like to see this test in open loop.
  4. #84
    Jun 2005
    I do not think this is related to Backub VE table as there is no Backup VE table in the 2002 OS I was using when I had this problem. Although I have a '99 C5 which originally uses this table...
    Marcin
  5. #85
    Nov 2003
    i just tested it out again today and now its now running lean with the MAF plugged in, but i swear it did yesterday. :-(
    i hope we can get the update soon, pulling my hair out
    My Trans Ams
  6. #86
    Lifetime Member jfpilla's Avatar
    Try this. Pull the fuse or disable the A.I.R. pump, by tuning and see if it's really only a false reading.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  7. #87
    Jan 2004
    Quote Originally Posted by jfpilla
    Mine is disabled all the time. Heck, I don't even have a A.I.R. pump....
  8. #88
    Nov 2003
    Quote Originally Posted by Black02SS
    i got rid of A.I.R. and egr
    My Trans Ams
  9. #89
    Jan 2004
    Shoots that idea....
  10. #90
    Jun 2005
    Yea, I don't have an AIR pump installed anymore either. Seeing the same thing at cold start-up.
    2000 Corvette Twin Turbo
    2004 CTS-V TVS 1900
    2006 TBSS TVS 1900
    All Tuned by
    Rad Tunes by Troy
    aka Vetteboy2k
  1. Lean AFR Problem
    By nm2769 in forum Custom Operating Systems
    Last Post: April 17th, 2010, 05:41 PM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. COS 04140003 lean problem
    By AGRO in forum Custom Operating Systems
    Last Post: June 23rd, 2007, 11:20 PM
  4. LS2 402 lean idle
    By white2000ta in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2006, 04:59 AM
  5. Lean idle?
    By Texas Terminator in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2006, 10:06 AM
