cruising around at low speed (30kph to 60kph) under light throttle the transmission is shifting back and forth between gears quite badly. It goes away when i put it in tow/haul mode (or hard throttle/high speed)
I had been messing around with the throttle span to try to help my towing shift pattern, but i have since returned it basically to stock & still have this condition.
any thoughts?
edit* when i bought the transmission from DTT they made sure i wasnt having this condition from the get go. apparently its something that can affect random trucks after the install. Mine worked fine, so i wasnt required to purchase their "shift enhancer" to fix the problem....just hoping i can tune it back out now & its not just some coincidental transmission problem....
