Results 1 to 5 of 5
Thread: How are you 96lb injectors at idle??
    Redline Motorsports
    Guest
    Default How are you 96lb injectors at idle??
    Been playing with a TT C5 with 96lb/hr injectors. Seems like no matter what we did the A/F was alway very rich. The rest of the fuel curve, cruising and WOT is on the money. Are just an problem or are there some tricks? Idle quality seemed fine despite the richer idle. It is too much injector for this car anyway but regardless its an idle problem.
    Any tips?
    Quote Originally Posted by Redline Motorsports
    Any tips?
    the injectors will have a min pulse width that they will operate at physically,even though you try and drive then lower they will not especially if you are using a driver box that will also have a min opening time. you will find no matter what you do the engine will want less than this to run at the right mixture at idle , with big injectora you can loose control of stuff like this , may have to drop fuel pressure at low rpm to enable you to get idle control and part throttle control
    Redline Motorsports
    Guest
    Thats what I figured... I did changed the min. pulse width time and it had no effect. Like I said this car could have got away with a 60's which most likely would not have the same problems. I never thought about the driver having a minimum threshold.........
    Apr 2005
    A simplistic way to look at injector sizing is;
    you can't open too small injectors big enough
    and
    you can't close too big injectors small enough
    Y2K mn6 MY vert
    TI Exhaust, Z06 airlid, EFI grad, kooks headers & x-pipe
    Lifetime Member MN C5's Avatar
    Mar 2005
    Redline, I've compensated with fuel pressure using a variable boost referenced fuel pressure regulator. It's a little harder to tune because the fuel pressure is rising faster than the boost but it allows you to make the beast idle. Its not the right way to do it but it works.
    http://www.holley.com/data/Products/.../199R10101.pdf
  1. 83lb injectors SD idle quality
    By B A Barakus in forum General (Petrol, Gas, Ethanol)
    Last Post: December 23rd, 2006, 11:04 PM
  2. 96lb injectors can be tuned to idle perfectly!
    By nitrorocket in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 20th, 2006, 03:50 PM
  3. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
  4. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: July 11th, 2006, 03:58 PM
  5. Who has 96lb injectors?
    Last Post: September 1st, 2005, 09:24 AM
