Results 1 to 10 of 15
Thread: 98 Corvette Bench Tune Help
    Junior Member Tuned55's Avatar
    Jan 2010
    Default 98 Corvette Bench Tune Help
    I've built another hot rod using a 98 Vette, auto trans. I'd like to learn how to remove the VATS and Emissions. Other than that I left the donor stock. I'd like help going through the process. I'm using the FlashScan V2.
    Have you read the PCM yet?
    If yes, then maybe post the file up and someone can sort you out.
    Aug 2010
    Hello Tuned55,
    Thanks to the kind folks at EFILive the LS1-A PCM does not require licencing - they are free to tune. In an emissions exempt Hot Rod application, the following should point you in the correct direction.
    VATS
    • G1201 - None
    • G0801 - No
    EGR
    • B1301 - Disable
    Then go the "Engine Diagnostics" folder, "Engine DTC Processing Enablers" subfolder ... set whatever devices are not in use to "Not Reported".
    Regards,
    Taz
    Jan 2010
    have not read it yet. I have it all ready but unsure where to plug it into my V2 FlashScan
    Need to have a standard OBDII connector wired up to the engine harness to read it. Or build a bench harness that has an OBDII plug, external power, and LS1 PCM connectors.
    Jan 2010
    Ok, I have two harness's to use. Where would I find more info for this. Or sould I just plug into one of my cars to do it?
    Not sure exactly what you mean Bruce, you need to have the factory OBDII connector from the donor vehicle hooked into the engine wiring harness correctly. On factory vehicles this is under the dash, not sure where you put it in your swap though. Once it is there (or if it still is), just hook your FlashScan up to it and use the V7.5 software to read the tune out.
    Jan 2010
    I was under the impression the ecm's could be flashed out of the vehicle on a bench. I have a couple old take out harness's I could have used for this purpose.
    Yes that can be done too, refer to the PCM Pinouts pdf. Open V7.5 tune or scan tool, click help->tutorials and select the pinouts or bench harness pdf (forget what its named).
    Check out www.eficonnection.com for some more ideas, they have some really nice bench harnesses. Even if just to look at and get a better idea of what you need to do.
    Aug 2010
    LS1-A and LS1-B PCM bench top type programming harnesses begin by using the same raw materials (C1 (Blue) connector) - but that is where the similarity ends - these must be wired differently (different pinouts) for LS1-A or LS1-B applications.
    Regards,
    Taz
  1. Loading tune with bench harness?
    By JoakimMD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2009, 04:57 AM
  2. Need a stock 99 Corvette tune please.
    By horsehaulin in forum Gen III V8 Specific
    Last Post: May 9th, 2008, 05:24 PM
  3. Tune 97 Corvette ?
    By RPO_Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2006, 05:23 PM
  4. Corvette Tune?
    By Bradazz in forum General (Petrol, Gas, Ethanol)
    Last Post: July 15th, 2006, 01:12 PM
  5. 2002 corvette tune
    By slickvic in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 1st, 2006, 04:39 PM
