Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 76
Thread: 2800 RPM Fuel Drop-Off
  1. #11
    Nov 2010
    Understood...my '07 has a 5733 designation and the '06 has a 5533...except for the middle 5 being a 7 on mine...it's close.
    Any forseen issues with putting a 5533 in a 5733???
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  2. #12
    Senior Member TexasCummins's Avatar
    Jul 2011
    I used to have this issue and fixed it unknowingly when I got the truck up to 3,400rpm today.
    I went to the injection quantity pedal position to desired fuel normal and transient graphs and changed the mm3 value for 25%, 50% and 100% values for every rpm to 200.
    EFI Live - The Smarter way to tune!
    2006 Ram 2500 4x4
  3. #13
    Mar 2009
    ok so after fighting this same fuel cut off i have a truck fully fueling to 4300rpm which is where i have the limiter set
    could not get it there using the stock tune as a base
    used SW9(non-4000rpm) as a base then ran my script over it and now it spins 4300 no problem at all, even tho the SW9 base tune was not capable of the rpm
    my conclusion is that there is a table that we cant see right now that the SW9 is changing that is fixing the defuel
  4. #14
    Jun 2011
    Quote Originally Posted by TorqueDieselLLC View Post
    I'm curious to see what the EFI team finds.
  5. #15
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    X2
    Spray & Pray
  6. #16
    Member bean's Avatar
    Jul 2011
    Through extensive testing and data logging I too have come to the same conclusion, there is a table we dont have yet. Smarty files do not cut back on desired fuel but anything EFI I have tried will start cutting it back around 2400rpms and peaks power at 2800. This would include copy and pasting every single table from a Smarty file into a fresh EFI tune.
    Pretty sure its a torque limiting table, if the % of maximum TQ PID goes over 100% it will immediatly start cutting fuel. The current TQ limit table doesnt do anything, you can put it at 1 or max it out and it changes nothing.
  7. #17
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    We have our truck full fueling to 3,600rpm, but commanded pulse width drops off starting at 2,800rpm and can really hinder the power above 3k. Is everyone else seeing this same problem? In testing we've upped the pulse time and timing and it's neither a pulse multiplier table or pulse timing limiter. It has to be a max pulse vs rpm table as another form of engine protection.
    Dan's Diesel Performance
    www.dansdieselperformance.com
  8. #18
    Nov 2010
    Quote Originally Posted by dansdieselp View Post
    To me it also seems like a uS vs rpm limiting table....weather I command 3000uS or 5000uS, it always pulls back to 2000-2200uS at 2800......but commanded mm3 stays at 145mm3 the entire pull up to 4100rpm's.
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
  9. #19
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    One of my issues was the pressure duty cycle... We could see the pressure start taking its effect as the dc% was going above 28. Being able to keep that at >24% allowed me to keep pressure and hold it and kept pulse (2450) all the way up to 3800 and then it takes a drastic drop. I have a customer logging a 3450 pulse this evening and i will report back the verdict. I have him a tune with stock DC and modified DC... I'm on vacation in panama, Fl so as soon as i get back on i will post the verdict! I will say without the necessary fp table modifications not timing, desired pressure, nor any other tables have had an effect on the limiter..the only one i have found in my case has been the duty cycle which is dependant on rpm. Again, i will report back. Thanks
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
  10. #20
    Jun 2011
    Quote Originally Posted by 2007 5.9 View Post
    To me it also seems like a uS vs rpm limiting table....weather I command 3000uS or 5000uS, it always pulls back to 2000-2200uS at 2800......but commanded mm3 stays at 145mm3 the entire pull up to 4100rpm's.~Les
    Interesting. My Commanded volume drops above 2900 rpm, with a corresponding change in duration. At times, the duration is a lot less than what is in the table. Also, I've seen the commanded volume go as low as 70mm3 at 3200 rpm and WOT.
  1. Slow engine rpm drop after rew
    By Ram Air IV in forum General (Petrol, Gas, Ethanol)
    Last Post: April 9th, 2011, 06:54 AM
  2. Temporarily tune around WOT fuel preesure drop?
    By samh_08 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 20th, 2009, 05:01 AM
  3. Throttle blip...why is RPM slow to drop?
    By KAZ MotorSports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 2nd, 2007, 08:28 AM
  4. Long term fuel trims from the drop down menu...
    By JR_VETTE in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2006, 05:21 AM
  5. RPM drop with TCC lockup?
    By DrX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 7th, 2006, 02:47 PM
