First question relates to the VE table, I want to know if auto smoothing of this table is reccomended ?
Second question relates to throttle cracker, I've been playing with this to make the engine fall to idle, it was staying two to three hundred RPM above idle and then slowly comming down after stoping or slowing down, now I have zeroed throttle cracker airflow in gear from 400 to 1600 and it seems to help but I still have a delay, what should I do from here ?
Related to the throttle cracker question, after making the adjustment I noticed it helped out my low RPM bucking (1000~2000 RPM), how does that make sense ?
Last question, what is the easyest way to lean startup and idle without messing with the running ?
Thanks for putting up with my Noobness.
Cheers
Jamie
