I just purchased a 2002 camaro which has some mild mods done including a cam. The car is tuned horribly and i am thinking about starting from a stock tune and removing the MAF to use a speed density tune. I have read the tutorial and understand how to get the custom os installed, but wondering how exactly SD tunes work.
What are the benefits? Is it simplicity? My previous efi tuning experience is all SD since there wasn't mafs on the engines.
Also SD mode what is the main fueling table used? Is this table more of a standard at xxx rpm and xx tps give this amount of fuel? Then you have all the other tables that affect this base table such as engine temp, map etc..
Is it frowned upon, because of complexity, to use the 3 bar os with a stock map sensor? I will eventually be building a supercharger kit but would like to tune and get familiar with the 3 bar tuning os. Then when i add a 3 bar map i will know how to use and tune with it.
Anyone can break down a bit more how SD works i'd appreciate it.
thanks
