Results 1 to 3 of 3
Thread: 09 Chevy truck with E38...ASPARK?
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default 09 Chevy truck with E38...ASPARK?
    Tuned on a 09 Chevy truck with the E38 ECM today. My ASPARK PID does not work on these like the 07 and down PCM's. How do you log these to find how much timing is coming from the low octane table?
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    Aug 2010
    Hello 67SS509,
    On the E38 I believe the PID you are looking for is E38.OCTSCL_DMA. This PID is the opposite of the LS1 ASPARK PID - when it is at 0% the ECM is using the High Octane spark table, when at 100% the ECM is using the Low Octane spark table - and percentage between these values is the weight applied to the respective spark table.
    Just getting acquainted with the E38 myself ...
    Regards,
    Taz
    Dec 2005
    Can't find that PID in my list. Think I have another problem going on since I updated. Gonna start a new thread on that.
  1. Swapping 12200411 PCM into 98 Chevy Truck
    By 350SS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2017, 01:05 AM
  2. 95 chevy truck .xml
    By Patrick in forum EFILive V4
    Last Post: December 15th, 2010, 01:34 PM
  3. Crank sensor relearn 97 chevy truck
    By Gregs in forum General
    Last Post: March 29th, 2010, 02:21 AM
  4. Need some help from a Chevy Truck Mechanic
    By BRD-PREY in forum Duramax LB7
    Last Post: March 2nd, 2009, 12:42 PM
  5. 2002 chevy truck, TM tune
    By ytry in forum General (Petrol, Gas, Ethanol)
    Last Post: May 15th, 2006, 07:13 PM
