Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Problems after update
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default Problems after update
    Just updated yesterday. All my files with PID arrangments were affected. Many of the PID's are missing including AFR.GM. How do I get them back?
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    Try:
    - connect V7 to vehicle and validating pids,
    - File->Enter VIN,
    - File->Select Controller,
    - on PIDs tab uncheck Supported, check Names, select All for System.
    Click on the Caption column heading to sort alphabetically on that column, then scroll down see if you can locate the pid(s).
    Dec 2005
    When I try to connect I get "FlashScan/AutoCal Firmware is not compatble with the installed EFIlive software"
    Tried the update again also...build 170 already installed.
    So now scan tool does not work or tune tool.
    What's my next move. Done updates before and they always worked with no problem.
    Update the firmware on your V2 using EFILive HAPI. Install V8 software, then open V8 Scan & Tune. Click the little V2 in the taskbar near the clock in windows. Click F6: Firmware, update bootblock if necessary then update the firmware.
    Dec 2005
    How do I update the firmware?
    Dec 2005
    OK...got everything updated but still missing PID's
    Commanded AFR and KR missing for example.
    Have Commanded Lamda though.
    E38/E67 uses AFRATIO and KNKRET.
    Dec 2005
    When I open Default Imperial.PID file or any file there is no KR or Commanded AFR in the list (supported unchecked)
    Dec 2005
    When I open "E38 ECM Metric.PID" AFRATIO and KNKRET are not in the list
    Quote Originally Posted by 67SS509 View Post
    See above.
    Info->Validate PIDs. Should be done after every update IMO.
  1. problems with V2 after doing new update
    By Dozerboy in forum FlashScan V2
    Last Post: April 4th, 2011, 11:55 AM
  2. To update or not to update?
    By jorge in forum General (Petrol, Gas, Ethanol)
    Last Post: September 17th, 2008, 03:23 AM
  3. New Update...
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 6th, 2007, 11:00 AM
  4. Update on I6
    By LSRacing in forum General (Petrol, Gas, Ethanol)
    Last Post: April 7th, 2006, 11:04 AM
