Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Problems after update
  1. #21
    Jun 2009
    Well, had some issues last night, but redownloaded the software and restarted my computer (something that I am not sure that I did previously) and when I validated the PIDs everything was back to normal (at least for my LB7 PIDs). So don't know if it was the intial automatic update that failed me or the fact that I may not have restarted the computer in that time.
    I listed my build and firmware versions in a "Reply" but it hasn't shown up yet. Now I just need to learn more about the BBx stuff. First off, need to research how to switch the PID units from metric to english. Well, actually like I have in the passthrough PIDs, I like my temps to be in fahrenheit but rail pressure to be in MPa, so I need to figure out how to change the units of each PID individually.
    Joecar,
    Thanks for the willingness to help.
  2. #22
    Default Units
    In scantool:
    - goto PIDs tab,
    - click on the column heading labbelled Units (this sorts the pid list on this column),
    - scroll up/down until you see a slab of pids with the same units (e.g. temperature),
    - using SHIFT and leftclick, highlight all the pids with the same units,
    - then without un-highlighting do rightclick and select either Metric or Imperial,
    - repeat for other slabs of pids,
    - close scantool.
    In tunetool:
    - goto Edit->Properties and select g*K/kPa and EQR, click Ok.
    - goto Edit->Configure Display Units,
    - then do the following for each of the columns labelled Data Units, Row Units, Col Units:
    - click twice on the column heading (sorts on this column),
    - using SHIFT and leftclick, highlight all rows with same units in this column,
    - do rightclick and select Data Value Units, Row Label Units, or Column Label units (to match this column) and select Metric or Imperial,
    - repeat for other slabs,
    - click Ok,
    - close tunetool.
  3. #23
    Yes, avoid the automatic update.
    Also see post #3 here: BBL-help
  1. problems with V2 after doing new update
    By Dozerboy in forum FlashScan V2
    Last Post: April 4th, 2011, 11:55 AM
  2. To update or not to update?
    By jorge in forum General (Petrol, Gas, Ethanol)
    Last Post: September 17th, 2008, 03:23 AM
  3. New Update...
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 6th, 2007, 11:00 AM
  4. Update on I6
    By LSRacing in forum General (Petrol, Gas, Ethanol)
    Last Post: April 7th, 2006, 11:04 AM
