Is source code available for EFI live software?
I noticed some discussion of the Linux software, how has anyone tested that without access to source code?
Access to source code: I doubt that very much. EFILive is not an "Open source" project so you are never going to get the code unless you buy the company.
Linux: The software works fine using the Wine wrapper, but you get no USB drivers. So what is possible at this time is to run the Scantool and Tunetool under Wine and save tune files to an SD card. Then you can flash the tune using BBF. However, managing the V2 / Autocal is not possible as you need the USB connection for that.
Simon.
I wasn't sure how people were running under Linux.
Didn't realize they were running wine.
