This should probably be in the v1 forum but it looked pretty dead so hopefully my question is okay here.
I've done quite a bit of searching on this but still haven't found a good answer on how to wire these together. The rest of the install looks fairly easy, just not sure exactly where to connect the white (analog) wire and if the blue wire is needed? Will I need any other wires besides the red, black, and white? Any help is appreciated.
Edit(found this picture later) If I'm looking at this correctly, white goes to C or E and another ground(guessing I add my own ground wire?) goes to D? ..then power to red and that's it? I know absolutely nothing about wiring unless it's Cat5 cable so please dumb it down for me if you don't mind. Appreciate any help!
