Results 1 to 10 of 16
Thread: Car will not idle...
    Jul 2011
    Default Car will not idle...
    Can someone check this tune? Cos3 2000 vette upgraded to 2002 OS then COS3. Going S/D trying to do VE tune but will not Idle. 427ci Auto, Car idles when cold but kills right after and will not idle again.
    Did I do or not do something correct?
    johnbcos3.tun
    look at your {B3647} "Commanded Fuel vs RPM" table for a start
    Also, fix these:
    Out of Range calibration summary: 09:07:19 am, Wednesday Jul 27, 2011
    EFILive Custom Calibrations
    {A0001} Forced Octane Scaler Percentage, was out of range when loaded.
    {A0002} Octane Scaler Limiter, was out of range when loaded.
    {A0009} Boost VE Table, contained one or more out of range values when loaded.
    {A0010} Boost Timing Table, contained one or more out of range values when loaded.
    and also A0012, A0013.
    See here:
    Look at B3647, as vxchev8 said above, this table is now incorrect for the ECT -> RPM axis change.
    Sanity check:
    - vehicle is 2000 Vette...?
    - what was your starting OS id...?
    Jul 2011
    OS12584929
    2000 vette
    Jul 2011
    Thank you for looking at the file. I did all the changes you suggested and still no Idle. Should I have to drill a hole in the TB? Here is the changed file. Thanks
    COS3.tun
    Jun 2007
    You shouldn't have to drill a hole. If you think you need more idle air, increase that, but don't drill.
    Jul 2011
    noticed MAP reading very high when I keep the throttle opened to stay running...around 10 at 1300RPM What would cause this?
    May 2010
    Post a log at idle.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Jul 2011
    log
    COS3.efi
  1. Replies: 1
    Last Post: March 15th, 2011, 08:17 PM
  2. Car Doesnt Like To Idle
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 31st, 2008, 08:43 AM
  3. Car Wont Idle And Runs Rich At Idle ( Tune Inside)
    Last Post: January 8th, 2008, 04:17 PM
  4. Can someone get my car to idle?
    By BrianC98Z28 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 25th, 2006, 11:41 AM
  5. What is your idle AFR??? My car wll not idle?
    Last Post: October 13th, 2005, 10:10 AM
