Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Runway lighting on E38 & E67 ECM's?
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default Runway lighting on E38 & E67 ECM's?
    Runway lighting works fine for me on 98-2006 PCM's but when try to use it on anything with an E38 or E67 ECm it doesn't. Example: On hi-octane spark table the RPM horizontal runway follows rpm's ok but the vertical air flow runway stays on the last coluum. Is there a trick to these that I'm unaware of?
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    On the scantool PIDs tab make sure the pid has the same units as the tunetool table axis.
    Make sure you're logging the same pid as the tunetool table axis.
    You can edit the linking pids, look for a file named cal_link.txt.
    Dec 2005
    The link at the top of my map is E38.APCYL_DMA and this was listed in cal_link B5913.COL=GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYL AIR,CALC.CYLAIR
    Do I add a coma and add E38.APCYL_DMA?
    Yes, exactly as you said...
    like this:
    B5913.COL=GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYL AIR,CALC.CYLAIR,E38.APCYL_DMA
    or like this:
    B5913.COL=E38.APCYL_DMA,GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYL AIR,CALC.CYLAIR
    (did you notice when you hover the cursor over the axis label a yellow box pops up listing all the pids after the first one).
    Dec 2005
    Just when I thought I had this whipped! Found the file on my desk top PC using Windows 7 but can't find it on my laptop using Windows XP. Is it suppose to be in the configuration folder? Never noticed before the cursor highlighting the PID's. Learn something everyday!
    Jul 2007
    Excellent! I've just gone and updated my references for all the dynamics tables! Works a treat, thanks joecar.
    Quote Originally Posted by 67SS509 View Post
    On WinXP, cal_link.txt should be located in this folder: C:\Program Files\EFILive\V7.5\Configuration
    Simon, you're welcome, it does make log/tune analysis easier
    Dec 2005
    It's amazing how well Joecar knows EFIlive and his willingness to help others! Thanks also from me.
    lol, thanks for the kind words.
    I like to see everyone succeed at using the software this software is the best engine/trans mod you will ever get
  1. Schematics for E67 & E38 hardware
    By NateD4 in forum E37, E38 & E67 PFI ECM's
    Last Post: August 11th, 2011, 01:20 PM
  2. E38 & E67 Matlab xPC Target OS??
    By NateD4 in forum Lounge
    Last Post: July 15th, 2011, 02:00 PM
  3. E38/E67 ECM Speed Density Virtual VE table
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: May 18th, 2008, 07:51 AM
  4. E67 & E38 pinouts needed.
    By nycblazer in forum E37, E38 & E67 PFI ECM's
    Last Post: March 6th, 2008, 03:36 AM
  5. Reading an E38 / E67 ECM
    Last Post: June 6th, 2007, 06:02 PM
