Results 1 to 3 of 3
Thread: e38 standalone, starts and dies after 2 seconds max
    Jul 2009
    Default e38 standalone, starts and dies after 2 seconds max
    Hello everyone
    I disabled VATS, used a 100 ohm resistor on he black and yellow wire. the car was running, then took it to a 3 min ride.... after that the car only starts and dies and throws code crankshaft relearn, do you have any ideas?
    thanks
    Jul 2009
    by the way, wiring and ecu,tcm are form a 2007 silverado
    Dec 2007
    Quote Originally Posted by miguelc View Post
    Hello everyone
    thanks
    Any codes?
    Crank learn wont work outside a regular production car. If you can scan coils and injectors you will see whether it is the ECM not letting the engine fire up or something else like wiring.
    If you are scanning you should see the injectors go to "on" as well as the coils. If its the ECM the injectors wont go to "on".
  1. E38 Standalone problems
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: April 26th, 2011, 04:49 PM
  2. Starts, reduced power, and then dies...
    By snax in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 27th, 2010, 10:57 AM
  3. LS1 PCM (2002 Corvette) problem - starts and dies in 2 secs
    By hIGGI in forum E37, E38 & E67 PFI ECM's
    Last Post: October 4th, 2010, 07:59 PM
  4. Loaded Custom OS: 03Z06..starts/dies after 1 sec
    By Earl H in forum Custom Operating Systems
    Last Post: May 7th, 2007, 08:55 AM
  5. starts for 1 sec and then dies
    By Cablebandit in forum Custom Operating Systems
    Last Post: April 8th, 2007, 12:32 PM
