Results 1 to 10 of 10
Thread: lost pids
    Feb 2010
    Default lost pids
    Hello everyone!
    I have an issue after updating efi (version170).
    In scantool where you choose pids , there is no longer pids for syl.balance rates, act. and des.rail press , inj. timing , dsp5 switch , nothing what you need to log LB7 or diesel
    there is pids for fuel rail ,and difference between actual and desired fuel press but it´s not supported
    I have been saved a pid list ,but when I open it nothing happened.
    First I couldnt do anything before updating firmware which is now 2.07.14 and bootblock 2.07.02
    now I´m totally lost , plesae help!!
    sorry for the bad language
    Hi hecatti welcome to the forum...
    you may need to reinstall V7 and V8 manually.
    Feb 2010
    thank you and thank you!!!!!!
    that fixed my problem
    Feb 2010
    hello again!
    now I have problem with flashing, when I check status it says:
    The Flashcan/Autocal firmware is not compatible with installed EfiLive software , please update the efilive software on your pc or laptop to the latest version and update the flashcan/autocal firmware that is
    distributed with the efilive v8 software , the latest efilive v7.5 and v8 software may be downloaded from efilive.com
    I tried several times but still no luck , is it possible continue and make the flash even if status is not ok?
    thank you already!!
    What V7 and V8 build versions are you at (post screenshots)...?
    What V2 bootblock and firmware versions are you at (use EFILive Explorer; post screenshots)...?
    The software/firmware versions must be compatible otherwise flashing will fail and the PCM/ECM will be bricked.
    Feb 2010
    well, I don´t know how to post screenshot, but my V7 is version 173 and V8 162
    V2 bootblock 2.07.02 and firmware is 2.07.14
    LB7 2001, EfiLive DSP5 , AirDog II, Afe intake , Summit 4"exhaust
    Ok, use EFILive Exporer (goto Firmware tab) and do this (in this order):
    - update V2 bootblock to 2.07.03 (checkmark Bootblock checkbox),
    - update V2 firmware to 2.07.16 (un-checmark Bootblock checkbox).
    Screenshots: see posts #2 and #3 here: Hosting-an-Image
    Feb 2010
    thank you for advice , I´l do that next and try again
    Feb 2010
    hello
    Finally I got everything up to date , it seems that new version was released again since yesterday and I was little lost (again) , but now everything looks good.
    thanks Joecar!
  1. Lost all wideband analog and serial pids
    By Wichita Dyno in forum General
    Last Post: August 23rd, 2010, 04:24 AM
  2. HELP: I am lost !
    By Lennart in forum Gen III V8 Specific
    Last Post: June 28th, 2010, 02:51 AM
  3. Lost PIDS / Calibrations
    By Big D in forum General (Diesel)
    Last Post: March 13th, 2010, 09:05 AM
  4. im so lost
    By dynarex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2007, 05:10 AM
  5. Ok I'm Lost
    By TLKSCHP in forum General
    Last Post: September 30th, 2006, 11:57 AM
