Results 1 to 8 of 8
Thread: Do I have to have a mass air meter?
    Junior Member O_Poole's Avatar
    Mar 2011
    Default Do I have to have a mass air meter?
    Would like to not run a mass air meter on my project.. It's a 5.7 with tea 215cnc trickflows, Cam cams will need to find specs thinking 230/238 @ .050, FAST intake 92mm tb, Bosch 42lb injectors.. In a LX mustang with a 6sp.
    Found out today with my efi live the pcm is out of a 5.3 truck? I have fired the car and let it idle some there is no throttle response..
    Thanks for any help!
    Jan 2006
    No, you can run it in Speed Density (SD), you just have to set it up in the pcm.
    Mar 2011
    Thank you sir! Can you point me in the right direction on how to do this thanks!
    will the truck 5.3 pcm be ok for this project? Or should i have a car pcm for a 5.7?
    Jan 2006
    What year motor, PCM and wiring harness are you using? Depending on year of PCM they are the same PCM in alot of cases in a car and truck just have different tune. Do you plan on running a custom OS? Depending on what year pcm you have the steps may vary alittle for SD.
    Mar 2011
    Motor out of a 2000 trans-am.. With TEA 215cnc TrickFlows, FAST intake with 92mm tb, Bosch 42lb injectors
    PCM is a 2000 truck 5.3
    Mar 2011
    Minytrker Thank you for your help today!!
    Jan 2006
    No problem, it was nice talking to you. Give me a call anytime.
    Mar 2011
    Cam is 234/238 @ 50 Lift is IN .601- EX .603 112 lobe sep
    Thanks!
  1. The NEW Mass Air Flow sensor
    By L31Sleeper in forum Conversions / Aftermarket Parts
    Last Post: December 22nd, 2010, 11:58 AM
  2. Airflow rate from mass air flow sensor (GM.MAF)
    By phils01z in forum Gen III V8 Specific
    Last Post: October 4th, 2010, 12:35 PM
  3. FAST Dual Sensor Air/Fuel Meter
    By Joel_SS in forum General (Petrol, Gas, Ethanol)
    Last Post: January 5th, 2008, 03:44 PM
  4. delta air mass spark...
    By brokenfly in forum General (Petrol, Gas, Ethanol)
    Last Post: May 10th, 2007, 03:10 AM
  5. 85mm Mass Air help
    By RandyWS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 10th, 2006, 12:43 AM
