Results 1 to 5 of 5
Thread: dreaded error $0331 when attempting reflash
    Jul 2011
    Default dreaded error $0331 when attempting reflash
    Good afternoon,
    I'm getting an error $0331 when attempting to reflash the e38 with a retune. The original e38 & T43 tunes were done using the full flash option on the autocal. There was a thread on here last year that mentioned an update that was suppose to remedy the issue. Thanks for the help!
    Download and manually install V7 and V8 from here: Pre-Release-Update-July-29-2011
    Then install bootblock 2.07.03 and firmware 2.07.17.
    Jul 2011
    I tried that but am still getting the error $0331.
    I notified Tech Support.
    Oct 2004
    Have you tried flashing with both the V7.5 and V8 software? Please see this knowledgebase article and email me (support@efilive.com) the trace file.
    Andrew
    EFILive Crew
  1. $0502 Error when attempting BBR on CMB849
    By vortecfcar in forum AutoCal
    Last Post: June 10th, 2011, 06:56 AM
  2. Error $0331
    By RULEMKR in forum AutoCal
    Last Post: January 26th, 2011, 09:39 AM
  3. bootloader error will not reflash
    By toolie in forum Duramax LB7
    Last Post: June 20th, 2010, 10:10 AM
  4. E38 will not reflash License error
    By markemac in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2009, 08:58 PM
  5. Error message after attempting to create new PID list
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: April 6th, 2008, 10:44 AM
