Results 1 to 10 of 13
Thread: 2000 to 2002 OS to COS sanity check questions
    Aug 2007
    Cool 2000 to 2002 OS to COS sanity check questions
    I currently run a 12205612 OS. I need to go to a custom OS for a 2bar tune. CLSD I am thinking. I am maxing out my maf at 4200 rpm and 65% thottle. Now for the questions:
    1. I need to change year of OS, so I am guessing 12212156 OS needs to be used AFTER I table by table swap my tune into the 12212156 OS? Any shortcuts here??
    2. How do I decide if cos3 or 5 is right for me?
    4. I am thinking at this point I can follow the tutorial for upgrading to a cos ?? What did I miss?
    5. Since I am currently running a tune someone built me long ago, I assume it would be smart to do the autove before starting this so my fuel will be close or is that just double work since its not to far off now?
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
    1. Yes. No shortcuts unless your 2002 file is stock.
    2. COS5 also has nitrous tables and alpha-N (TP) VE table in case you ever need these.
    4. If your car runs on the 2002 file at least as good as it ran on the 2000 file, then yes you can go ahead and upgrade, remember to edit the OOR tables and set B3647 to suitable values (i.e. so you can idle).
    5. Yes, you could do this first since your already running fairly good on the 2002 file. You could do AutoVE, but also see the Calc.VET and Calc.MAFT tutorials (which can be tailored) (BTW: AutoVE is a special case of Calc.MAFT).
    Aug 2007
    I am on the 2000 os now.
    Aug 2007
    Red face
    I am on the 2000 os now. Far from stock tune. Running 9 lbs of boost.
    Ok, first get it running on the 2002 12212156 file, it should run the same...
    open two instances of the tunetool, and use copy-with-labels and paste-with-labels, work thru each table that is different, go slow be accurate...
    remember to save the 2002 file before flashing.
    Nov 2007
    I would work on tuning AFTER all the table swaps and the COS upgrade.
    If you AutoVE now where do you put the boosted data ??
    -Justin
    Justin has a good point.
    Aug 2007
    Thanks! ! !
    Aug 2007
    Where are the benefits and limitations of each COS listed?
    THANKS...
    Nov 2007
    There is a PDF for 1,2,3 but for 5 it's pretty much a long thread on here.
    COS 5 Sticky <===
    -Justin
  1. Sanity check of logs
    By stigmundfreud in forum Gen IV V8 Specific
    Last Post: July 5th, 2010, 11:33 AM
  2. Sanity check please
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: June 9th, 2010, 12:52 PM
  3. sanity check of semil-OL OEM tune
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: October 5th, 2008, 12:05 PM
  4. Sanity Check on Commanded AFR
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2007, 03:34 AM
  5. Sanity check, please?
    By critter in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2007, 02:14 PM
