Results 1 to 5 of 5
Thread: Turning off rear O2 Sensors?
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Default Turning off rear O2 Sensors?
    Below are the codes I set to X Not Reported under DTC Type amd No MIL under DTC MIL.
    Are there anymore that need to be turned off? I just installed headers without cats. I have a 2011 Camaro L99.
    P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
    P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
    P0140 HO2S Circuit Insufficiency Activity Bank 1 Sensor 2
    P0141 HO2S Heater Circuit Bank 1 Sensor 2
    P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
    P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
    P0160 HO2S Circuit Insufficiency Activity Bank 2 Sensor 2
    P0161 HO2S Heater Circuit Bank 2 Sensor 2
    P0420 Catalyst System Low Efficiency Bank 1
    P0430 Catalyst System Low Efficiency Bank 2
    What about PO13a to 13F? It looks like I should turn them to X.
    Thanks.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Aug 2010
    Hello Bill,
    Take a look at the thread linked below ... it was 2010 Camaro in that thread ...
    http://forum.efilive.com/showthread....ble-O2-sensors
    Regards,
    Taz
    Nov 2003
    Thanks. I had a list for the LS1 but the E38 has a lot more and just wanted to make sure I did not miss any.
    Bill
    Hi Bill, how's it going
    Yes, E38 is way different as you have found out.
    Nov 2003
    Everything is going great. So this is what I am changing for anyone else that see this thread.
    To fully disable the rear O2 sensors, in the “DTC Type” folder set the following to “Not Reported”:
    P0036
    P0054
    P0056
    P0060
    P0137
    P0138
    P013A through P014B
    P0157
    P0158
    P0160
    P0161
    P2270 through P2273
    Setting all of these to “Not Reported” should eliminate the MIL light coming on. If you want, you can also set the above parameters to “No Mil” in the “DTC MIL” folder.
  1. Setting rear O2 sensors to act as bank 1 (primary) O2 sensors
    By T34418L31 in forum Gen III V8 Specific
    Last Post: November 6th, 2010, 03:59 PM
  2. Rear O2 sensors for e38 VE V8 or G8?
    By hymey in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2010, 10:32 PM
  3. rear 02 sensors
    By aaronr in forum Gen III V8 Specific
    Last Post: December 17th, 2007, 01:38 PM
  4. Disable rear o2 sensors?
    By Dlong in forum Gen III V8 Specific
    Last Post: January 6th, 2007, 11:16 AM
  5. rear axle max torque and rear prop shaft numbers
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2006, 04:10 PM
