Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: My quest to tune my car...
  1. #11
    Apr 2011
    third log. same issue pretty much.
    can i use the values i get when i average map A and map B without applying the closed loop filter?
    Every time i apply the closed loop filter all my values drop to 0
    third log attached:
    calcvet3.efi
  2. #12
    OK start over and log the Fuelsys PID, it will tell you if you're actually getting into CL or not.
  3. #13
    CL=1 means Closed Loop if engine is at operating temperature and your have LTFT/trimming enabled.
  4. #14
    I'm out of town this week so I can't view your files.
  5. #15
    Apr 2011
    okay this is a picture of map A before filtering anything except for low cell counts:
    this is a picture of map A after using the calc_vet filter
    this is a picture with the CL filter...
    this is a picture of map B before filtering anything but low cell counts
    this is a picture of map b after calc_vet
    this is a picture of map b after CL filter
    This is what my CL filter is set up to look like...per tutorial:
    but then when i change calc_vet filter to EXCLUDE all frames where calc.cl is less than 1 like so...
    which when i apply to my map A...i end up with a map like so:
  6. #16
    Ok, change the filter to include CL=1 (or to exclude CL=0).
    Think about what CL stands for...
  7. #17
    Apr 2011
    :-) it made sense to me, but unfortunately, so does mixing dr. pepper and moscato wine....
    thanks a lot. i now know i can trust those values (relatively speaking of course) to make minor tweaks until my wb02 situation is resolved.
    <3
  8. #18
    Apr 2011
    next step is getting a decent log. the logs i have only have about 30 miles or so of travel on them (which is eqv to an hours worth of driving around here). they don't look like any of the logs that the other threads have in them.
    is there a safe "goal" for counts per cell? some sort of target number i should achieve in order to get a better average?
  9. #19
    Try to get better than 10 hits per cell.
    Operate the throttle is a smooth steady manner, this produces better data (the filter throws away less of it).
  10. #20
    Apr 2011
    my question now is about smoothing...
    i took a log, did the copy/paste with labels in the ve main and the b5001 maf table (multiply with labels in that table)
    in the ve table, there were tons of spikes everywhere, should i utilize smoothing in order to get the curve back?
  1. Tune pulled from car i bought. Can anyone look over it and help?
    By FlipediS in forum Gen III V8 Specific
    Last Post: May 12th, 2011, 07:32 PM
  2. Disappointed! Can't tune my RENTAL CAR!!!
    By Chuck CoW in forum General (Petrol, Gas, Ethanol)
    Last Post: February 3rd, 2009, 03:26 AM
  3. i put a tune in a car
    By stripes in forum Gen III V8 Specific
    Last Post: May 27th, 2008, 08:33 AM
  4. Can someone help me tune my car???
    By WiseGuyZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 27th, 2006, 03:12 PM
  5. SD tune: Car won't idle properly
    By Scott(382-$T$) in forum General (Petrol, Gas, Ethanol)
    Last Post: November 25th, 2006, 05:10 AM
