Results 1 to 9 of 9
Thread: FJO Wideband & EFIlive?
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default FJO Wideband & EFIlive?
    Just got my EFIlive and coming up to speed on using it. Great so far! Have been blackbox logging some runs and now I want to use my FJO wideband with it. Will I be able to actually wire the FJO to the side connections and configure a volts vs. O2 PID file to accept it? Or will I have to buy a different wideband?
    Sep 2003
    I am running the FJO i set up the output for .5-4.5 volts and the formula for the calc pid is afr=v*2+8.75. Happy tuning
    Larry - HumpinSS
    Dec 2005
    Hey...thanks for the reply. The output from my FJO controller is a serial cable with 4 wires. Black, Red, White and Green. Can you tell me which colors connect to which connectors on the black box. I might just have to send you a 6-pack!
    Jan 2004
    Quote Originally Posted by 67SS509
    He likes Bud Light...
    Sep 2003
    Ill look when i get home but the wire that powers the wideband has to blank pins onei s ground and the other is the signal. use some of the wire and pins they sent with the kit to add your outputs on the other two spots on the power cable and you will be golden
    Larry - HumpinSS
    Dec 2005
    Quote Originally Posted by Dirk Diggler
    Guess I was not looking on the right end of the controller. On the input cable...plain as day....ground and analog output! You must have the newer controller that you can adjust the output to read .5 to 4.5. Mine is older and will not do that. Guess I'm going to have to reconfigure EFIlive PID to accept it.
    Sep 2003
    the older controler is a non-linear output GOOD LUCK with that(ihad one too). You can call FJO and have them upgrade it to the newer style box which is programable and accepts both sensors (Ive trashed 3 ntk's allready and its getting expensive) the bosch sensor being 80+ to aquire from them.
    Larry - HumpinSS
    Dec 2005
    Did you ever get your old one to work and if so what was the formula for conversion?
    Sep 2003
    Nope i sure didnt by the time FS was available they offered an upgrade and I sprung for that instead of fighting with it. I think the upgrade is about 75.00 bux and will allow you to run both the NTK and Bosch sensor. Your existing NTK will have to be snet to them so the cable end can be upgraded
    Larry - HumpinSS
  1. wideband pid help......
    By blackbeast ss in forum Gen III V8 Specific
    Last Post: August 29th, 2009, 04:47 PM
  2. Wideband
    By pdasterly in forum Gen III V8 Specific
    Last Post: November 16th, 2008, 08:16 PM
  3. rr & wideband...
    By rubbersidedown in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 5th, 2007, 08:39 PM
  4. Need help with my wideband pls..
    By 5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 29th, 2007, 01:47 PM
  5. fjo wideband
    By articSS in forum External A/D inputs
    Last Post: May 27th, 2007, 09:02 AM
