Results 1 to 6 of 6
Thread: E38 6.0 Streetrod/Stanalone Swap - Very little ignition TIming
    Aug 2011
    Default E38 6.0 Streetrod/Stanalone Swap - Very little ignition TIming
    Hoping someone can help me out-
    I've installed a 2008 6.0 and transmission into a street rod. I have a timing problem. The engine runs proper timing at idle and part throttle cruise, but as you tip into the throttle the timing decreases significantly all the way down to the 0-5 degree range. I have shut off all of the normal things you would in a street rod type application. I am using the T42 TCM. I am using a E38 ECM with a 2007 4.8 liter calibration to get around the cylinder de-activation system.
    There are no codes in the ECM or TCM, but I'm thinking there is something that it doesn't like.
    Any help or educated thoughts would be appreciated!
    Jim
    Feb 2006
    A log and a tune file will help out.
    Al
    Feb 2006
    sorry duplicate
    Dec 2007
    Is "tip in" torque mgt active?
    OK, we definitely need a tune if you're trying to use a different OS with a different size engine. Did you set the cylinder volume correctly?
    Are you running a MAF?
    What do you mean "get around the cylinder deactivation", just using a tune without it doesnt turn it off...you should really disable everything from the original tune (or a tune for your engine from a different platform).
    2013 Sonic RS Manual - 1.4L I4T E78, starting the mods
    Jul 2007
    There are a number of things that may be causing this.
    • Torque Reduction from the TCM.
    • Torque Reduction in the ECM.
    • If the original tune file was for a manual, you may be triggering CFCO timing.
    • Any of the many spark correction maps for ECT, IAT, ETC.
    As Erik says, post a log and the tune.
    Simon.
  1. e38 4l80 swap 07 silverado cant get speedo to work???
    By b18cls1 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 6th, 2010, 01:45 AM
  2. Ignition timing issue,bank to bank
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: December 5th, 2009, 11:38 AM
  3. E38 AC management in an engine swap...
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2009, 09:48 PM
  4. Transmission swap in E38/E67 vehicle.
    By XLR8NSS in forum Gen IV V8 Specific
    Last Post: February 2nd, 2009, 09:04 AM
  5. Ignition Timing
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2006, 02:47 AM
