Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 59
Thread: Release Candidate 1, Aug 04, 2011
  1. #11
    Mar 2010
    I just tried to Copy and Paste Calc.VET PIDs from V7 to V8 and nothing happened... Am I doing something wrong?
  2. #12
    Quote Originally Posted by MikeyC View Post
    Calc PIDs are not supported directly in V8 therefor they are not supported during copy/paste operations.
    To specify calc PIDs in V8 click on the [V7] button in the BBX setup window and enter the calculated PIDs that you want active when you view the data in the V7 Scan Tool software.
  3. #13
    Mar 2010
    Thanks Blacky, I'll give that a try.
  4. #14
    Dec 2009
    Hey guys i apologize if this has been discussed recently in another thread but has there been any progress to support flashing a a50 tcm? thanks
  5. #15
    Jennett_c, I was hoping to get that in this release but once again that wretched TCM is causing me grief, I had to put it aside so we could try to finalise these releases.
  6. #16
    Dec 2009
    ok no problem. just checking haha
  7. #17
    A series of flash failures with the latest release candidate software has been identified. The following issue has been added to post #1.
    Issue #3
    Flashing some VPW based controllers may fail.
    Full Flashing an E35 (LBZ/LMM) will fail with $0322 at about 80% completion.
    Flashing an E60 (LLY) will fail.
    Please use the V7 software to flash the above vehicles.
  8. #18
    Jan 2006
    Just did update and now I CAN'T connect to E38 with scan tool. I tried two different vehicles one of which I own and mess with all the time so I know its not the vehicle. I can BBL but no matter what I do the scan tool will not connect. I tried different cables with no luck. I can connect and data log with auto cal or a V2 but can not connect through the scan tool. I can read and flash the ECM with my laptop through V8.
    EDIT: I went back to the last build for V7 and V8 and it works...I tried the latest updates twice and both times I couldnt connect the scan tool to E38 vehicles.
  9. #19
    Lifetime Member Chalky's Avatar
    Sep 2003
    It might just be me but the latest release has crashed my system twice now. System in 64 bit WIN 7 Toshiba. Both crashes occurred when reviewing scantool data.. Once with TuneTool open as well. My screen slows and I lose mouse function. I had to do restore to regain system function and reinstalled mouse drivers to get system back. Also had to install a usb mouse to get system working.
    By chance, it is possible to download the July 18th releases of 7.5 and V8?
    2015 Z06 A8
  10. #20
    Nov 2006
    Quote Originally Posted by minytrker View Post
    I too have found passthru fails to log E38 but BBL works.
    Build 176
    LC-1 WBO2
  1. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
  2. February 26th 2011 release candidate 1
    Last Post: March 4th, 2011, 09:55 AM
  3. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
