Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
Thread: Release Candidate 1, Aug 04, 2011
  1. #21
    Quote Originally Posted by Chalky View Post
    It might just be me but the latest release has crashed my system twice now. System in 64 bit WIN 7 Toshiba. Both crashes occurred when reviewing scantool data.. Once with TuneTool open as well. My screen slows and I lose mouse function. I had to do restore to regain system function and reinstalled mouse drivers to get system back. Also had to install a usb mouse to get system working.
    By chance, it is possible to download the July 18th releases of 7.5 and V8?
    The previous releases are still available here:
    http://forum.efilive.com/showthread....e-July-29-2011
  2. #22
    Lifetime Member Chalky's Avatar
    Sep 2003
    Forgot, have latest firmware. No going back I guess.
    2015 Z06 A8
  3. #23
    Dec 2006
    My system is is also crashing, Had to reintall a disk image to fix. Will wait for next release to try again as I also updated the firmware.
    I know there is a way to go backward, but not sure how to do it.
  4. #24
    Dec 2006
    Blacky could you post how to revert to an older firmware version?
  5. #25
    Jan 2006
    Going back to the previous release I now had PID's that don't work. I still have problems with connecting, it took me 45 mins just to download a tune and to get the scan tool working.
    How do I go back to the last firmware and bootloader? It won't you do it by the normal update methods.
    I lost almost a $1,000 dollars today and had to customers drive over 2 hours each and I couldn't tune there vehicles. I need to go back to the last version really bad.
  6. #26
    The attached firmware should work with build V8.2.1.166-167 and V7.5.7.176-177.
  7. #27
    Sep 2003
    Thank you!
    2015 Z06 A8
  8. #28
    Dec 2006
    Thank you for the quick reply
  9. #29
    Jan 2006
    How do I go back to the firmware before 166 and 176.......ALL my problems started when I went to the new firmware and to build 166 and 176. I can't afford for it not to work, so I know my V2 works with the previous build and firmware. Insn't there a manual way to override and flash the firmware back to an older version?
  10. #30
    Dec 2006
    Quote Originally Posted by minytrker View Post
    I have the same problem as you, at least you only lost money, I lost two LBZ computers I had to replace and program back to stock tunes with Tech II, I can not communicate with the ecm any more.
  1. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
  2. February 26th 2011 release candidate 1
    Last Post: March 4th, 2011, 09:55 AM
  3. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
