Results 1 to 5 of 5
Thread: beginner question
    New Member redls1bird's Avatar
    Jan 2006
    Default beginner question
    Hey guys, ive been spending day and night on this sight trying to soak up some good old fashioned knowledge from you experienced guys. sofar ive picked up quite a bit, but i am sometimes confused by the abbreviations used here. is there a place i can look them up? if not id be willing to try and compile one if a mod is interested in making it a sticky somewhere. just a thought. also, ive been under the impression that a maf system is better than a speed density type since it is actively adapting to changes in incoming air. after reading this forum i see that alot of you guys are going to speed density, even on n/a applications. can someone point me to a post or give me some insight to why this is the way to go? thanks in advance.
    Oct 2005
    The maf vs SD argument is still going well. A search on ls1.com.au or ls1tech will bring up loads of threads on the argument.
    FWIW my understanding at present is that SD is more responsive to throttle and of course doesnt restrict airflow. MAF measures airflow and compensates for mods easier and can result in better economy. SD needs a retune for each change that might affect VE.
    Well closed loop kind of patches SD up, but thats the general gist from my understanding.
    I chose SD for max power and response, plus its stage one in tuning as its used to dial in VE. ( I reflash the PCM pretty much every time I get in the car )
    If I wanted a tune and forget arrangement Id probably go Maf tune. (tune then never flash again)
    2014 VF SV LS3 Maloo.
    Oct 2003
    Quote Originally Posted by redls1bird
    Here are some abbreviations/acronyms ->
    http://www.efiforum.iqd.co.nz/showth...p?t=156&page=2
    joel
    Nov 2003
    Talking
    Quote Originally Posted by ringram
    And I thought I was the only one that does that.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Aug 2005
    Quote Originally Posted by BowlingSS
    Bill
    I've re-flashed my truck at least 120 times now. Is there any other way to drive?
  1. New beginner's Tuning Guide (DVD) from Calibrated Success
    By eficalibrator in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2010, 04:49 AM
  2. anything for an 09 V6? EFI live beginner...
    By dieselsmith in forum Gen III V8 Specific
    Last Post: January 30th, 2010, 03:05 PM
  3. beginner / need help
    By sharpshooter in forum FlashScan V2
    Last Post: December 3rd, 2009, 05:44 AM
  4. Beginner question re: 2003 LM7 5.3 Vortec
    By Jon95YJ in forum Gen III V8 Specific
    Last Post: November 6th, 2008, 05:23 AM
  5. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 02:22 PM
